CrowPanel Advance 2.4-HMI ESP32 AI Display
Model DIS01624A
advance-2.4-00
Pin Output:
advance-2.4-0
Functional description
SPK Output audio signals to connect to speakers. The main board comes with a power amplifier chip circuit. PH2.0-2P
PWR Power LED.
boot
UART1-OUT Builds communication between Logic modules, including the serial communication module and the print module. HY2.0-4P
UART0-IN Input power supply and serial communication functionality XH2.54-4P
I2C-OUT Establish communication between the microcontroller and peripheral devices. HY2.0-4P
BAT Connect the lithium battery. (with battery charging circuit)(Input voltage: 3.7–4.2 V) PH2.0-2P
2.8-inch HMI port pin number Electrical Characteristics
UART1-OUT RX(IO18); TX(IO17) RX; Output voltage: 3.3V
Output current: 1A max.
Use: Power supply output and communication.
UART0-IN RX(IO44); TX(IO43) RX; Input voltage: 5V ± 5%. 5.5V max.
Input current: 2A max.
Purpose: Power supply input and communication.
I2C SDA(IO15); SCL(IO16) ; Output voltage: 3.3V
SPK I2S_LRCLK(IO11);I2S_BCLK(IO13);I2S_SDIN(IO12); Maximum output current: 20mA
Signal type: 3.3V logic level, digital control signal
SD Card Slot MOSI(IO6); MISO(IO4); CLK(IO5); CS(3.3V) Maximum output current: 20mA
LCD Backlight IO38 Maximum output current: 20mA
I2S MIC MIC_SD(IO10);MIC_WS(IO3);MIC_CLK(IO9) Maximum output current: 20mA
BUZZER IO8 Maximum output current: 20mA
Switching Function Keys:
IO45 level effective function
1 MIC
0 WM(wireless module)
Schematic:
ESP32-S3 and ISP Display Wiring Pins:
advance-2.4-1
ESP32-S3 and Touch Driver Wiring:
i2c address: 0x38.
advance-2.4-2
ESP32-S3 and wireless module wiring pins:
advance-2.4-3
1 MIC
Wireless module pins:
image-20250108175238121
IO1 IO2
IO10 IO16
IO9 IO15
IO3 NC
3V3 IO46
GND IO0
5V NC
New Version Update
V1.1 upgraded, optimized the amplifier circuit, better sound quality, and use IO21 to control mute. i2s_mic changed to two pins IO9 and IO10 control.
advance-2.4-1.2
Version 1.2
Only the button component has been updated. All other hardware and I/O pins remain the same as in the previous version.
Platforms Supported
Arduino IDE ESP-IDF PlatformIO
Arduino ESP-IDF-Logo.webp platformIO
Arduino IDE View Tutorials -- V1.0
Arduino IDE View Tutorials -- V1.1/V1.2
ESP-IDF View Tutorials -- V1.0
ESP-IDF View Tutorials -- V1.1/V1.2
platfoemIO View Tutorials -- V1.0
platfoemIO View Tutorials -- V1.1/V1.2
ESPHome SquareLine Studio Meshtastic
ESPHome View Tutorials -- V1.0/V1.1/V1.2 SquareLine Studio View Tutorials -- V1.0
SquareLine Studio View Tutorials -- V1.1/V1.2
GetStarted
Thread Wireless ESP-matter
Wireless_Module-ESP32-H2 Wireless_Module-ESP32-H2
GetStarted GetStarted
Resources
Github link:
Wireless link:
How to buy
Please visit this page to purchase ESP32 Display-2.4 inch(Advance_Series).
Support
