Crowbits-DC Motor
The DC motor is a digital output module, it’s a rotary electrical machine that converts direct current electrical energy into mechanical energy. Use the DC motor, you can make your projects spin, turn and twist.
  • Easy to use
  • Operating Voltage: 3.3V DC
Usage
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an input module, such as Crowbits-Button.
3. Turn on the power.
1)Set the toggle switch on the DC Motor board to F, when you press and hold the button, you can see that the DC motor is rotating forward;
2)Set the toggle switch on the DC Motor board to R, when you press and hold the button, you can see the DC motor reverse.
