Crowbits-Gesture Sensor
The sensor on Crowbits-Gesture is PAJ7620U2 that integrates gesture recognition function with general I2C interface into a single chip. It can recognize 9 basic gestures, and these gestures information can be simply accessed via the I2C bus. You can use Gesture as an input device to control another module, or a computer, mobile phone, smart car, robot, and more with a simple swipe of your hand.
  • Built-in proximity detection
  • Gesture speed in Normal Mode: 60°/s to 600°/s
  • Ambient light immunity: < 100k Lux
  • Gesture speed in Gaming Mode: 60°/s to 1200°/s
  • Interface Type: I2C
  • Operating Voltage: 3.3V DC
  • Dimensions: 31.5(L)*24.5(W)*13(H)mm
Usage
1.You need to prepare a Crowbits motherboard, such as Crowbits-UNO board.
2.Connect the module to the I2C interface on the Crowbits-UNO board, as shown in the figure:
3.Download the library “Paj7620”. Unzip and put it in the libraries file, for example: C:\Program Files (x86)\Arduino\libraries.
4.Upload the following code to the Crowbits-UNO board.
 * Copyright (c) 2015 seeed technology inc.
 * Website    : www.seeed.cc
 * Author     : Wuruibin
 * Modified Time: June 2015
 * Description: This demo can recognize 9 gestures and output the result, including move up, move down, move left, move right,
 *              move forward, move backward, circle-clockwise, circle-counter clockwise, and wave.
 * The MIT License (MIT)
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 * THE SOFTWARE.
#include <Wire.h>
#include "paj7620.h"
Notice: When you want to recognize the Forward/Backward gestures, your gestures' reaction time must less than GES_ENTRY_TIME(0.8s).
        You also can adjust the reaction time according to the actual circumstance.
#define GES_REACTION_TIME       500             // You can adjust the reaction time according to the actual circumstance.
#define GES_ENTRY_TIME          800             // When you want to recognize the Forward/Backward gestures, your gestures' reaction time must less than GES_ENTRY_TIME(0.8s).
#define GES_QUIT_TIME           1000
    uint8_t error = 0;
    Serial.println("\nPAJ7620U2 TEST DEMO: Recognize 9 gestures.");
    error = paj7620Init();          // initialize Paj7620 registers
    if (error)
        Serial.print("INIT ERROR,CODE:");
        Serial.println(error);
    else
        Serial.println("INIT OK");
    Serial.println("Please input your gestures:\n");
    uint8_t data = 0, data1 = 0, error;
    error = paj7620ReadReg(0x43, 1, &data);             // Read Bank_0_Reg_0x43/0x44 for gesture result.
    if (!error)
        switch (data)                                   // When different gestures be detected, the variable 'data' will be set to different values by paj7620ReadReg(0x43, 1, &data).
            case GES_RIGHT_FLAG:
                delay(GES_ENTRY_TIME);
                if(data == GES_FORWARD_FLAG)
                    Serial.println("Forward");
                    delay(GES_QUIT_TIME);
                else if(data == GES_BACKWARD_FLAG)
                    Serial.println("Backward");
                else
                    Serial.println("Right");
                break;
            case GES_LEFT_FLAG:
                else
                    Serial.println("Left");
                break;
            case GES_UP_FLAG:
                else
                    Serial.println("Up");
                break;
            case GES_DOWN_FLAG:
                else
                    Serial.println("Down");
                break;
            case GES_FORWARD_FLAG:
                break;
            case GES_BACKWARD_FLAG:
                break;
            case GES_CLOCKWISE_FLAG:
                Serial.println("Clockwise");
                break;
            case GES_COUNT_CLOCKWISE_FLAG:
                Serial.println("anti-clockwise");
                break;
            default:
                paj7620ReadReg(0x44, 1, &data1);
                if (data1 == GES_WAVE_FLAG)
                    Serial.println("wave");
                break;
    delay(100);
5. After the upload is successful, open the serial port monitor, the baud rate is set to 9600. When you gesture to the sensor, the serial port will print out the corresponding gesture, as shown in the figure.
