Crowtail- Dust Sensor
A NEW Crowtail product! we add a crowtail port for pluging into crowtail base board. so it can simple use for our Crowduino. The dust sensor module DSM501A is low cost, compact size for a particle density sensor.it is used to quantitative particle (> 1 micron) measurement with the principle of particle counter, can sense the tobacco smoke and pollen, house dust . This sensor is consist of light emitting diode lamp, detector, signal amplifier circuit and heater, it can be used in applications such as the air cleaner or air purifier, users can used this sensor easily with sensor PWM output.
Model: CT0039DSD
Feature¶
- PWM Output
- Compact size and lightweight
- Easy installation
- 5V Single power supply
- Dimensions(mm):58.5(L)x45.0(W)x18.5(H)
1.Hardware connection
2.Copy and paste code below to a new Arduino sketch:
#include<string.h>
byte buff[2];
int pin = 8;//DSM501A input D8
unsigned long duration;
unsigned long starttime;
unsigned long endtime;
unsigned long sampletime_ms = 30000;
unsigned long lowpulseoccupancy = 0;
float ratio = 0;
float concentration = 0;
int i=0;
pinMode(8,INPUT);
starttime = millis();
duration = pulseIn(pin, LOW);
lowpulseoccupancy += duration;
endtime = millis();
if ((endtime-starttime) > sampletime_ms)
ratio = (lowpulseoccupancy-endtime+starttime + sampletime_ms)/(sampletime_ms*10.0); // Integer percentage 0=>100
concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve
Serial.print("lowpulseoccupancy:");
Serial.print(lowpulseoccupancy);
Serial.print(" ratio:");
Serial.print(ratio);
Serial.print(" DSM501A:");
Serial.println(concentration);
4.Open the serial monitor. You should the test result.
