CrowPanel PICO HMI 2.8'' Display
The Pico 2.8” Display has a resolution of 320*240 and comes with a touch pen for flexible screen manipulation. It has flexible I/O peripherals and a unique programmable input/output (PIO) subsystem, including practical communication interfaces such as I2C, UART, common IO ports, and USB. It also features a lithium battery interface and a buzzer alarm, enabling communication with almost any external device. This provides professional users with flexibility and powerful expandability, allowing seamless connection to the physical world and control of various aspects of smart homes.
The module comes with abundant resources, including development SDK, documentation. It has a very low entry barrier, making it suitable for beginners and hobbyist users. It not only can use Arduino IDE, MicroPython, PlatformIO and CircuitPython to program, but also supports the LVGL graphics library and Squareline Studio to customize the desired UI interface. It serves as an excellent platform for machine learning applications and is the preferred solution for Pico-like HMI interaction terminals.
Model: DIS01028P
2.8
Alt text
  • RP2040 Microcontroller: Equipped with a 32-bit dual-core chip, it achieves a maximum clock frequency of 133 MHz.
  • TN Panel: Offers a wide color gamut and exceptional brightness for optimal display performance.
  • Energy Efficiency: Supports low-power sleep and hibernation modes, promoting energy conservation and environmental consciousness.
  • Exceptional Extensibility: A wealth of interfaces, including I2C, UART, IO ports, USB, a lithium battery interface, and a buzzer alarm, ensures remarkable extensibility.
  • Broad Compatibility: Support multiple programming environments.
  • Versatile Applications: Ideally suited for a wide range of applications within the Internet of Things (IoT), intelligent home control, smart factories, intelligent agriculture, and as an HMI interactive terminal.
  • Main Chip: RP2040
  • Processor: Dual-core 32-bit ARM Cortex-M0+ @ 133MHz
  • Memory: 264kB on-chip SRAM (supports up to 16MB of off-chip flash memory)
  • Screen Size: 2.8 inch
  • Resolution: 320*240
  • Signal Interface: SPI
  • Touch Type: Resistive Touch
  • Panel Type: TFT LCD
  • Power Input: 5V-2A
  • Active Area: 43.2 * 57.6mm(W * H)
  • Dimensions: 57 * 88.7 * 13.4mm(W * H * D)
PinOut
Pin Name Description Connect Type
PWR Power LED.
BOOT Hold the BOOT button and press RST button to make the RP2040 enter flash mode.
TF Provide off-line save and extra storage space.
UART0 Build the communication among Logic modules, including serial communication module and print module.
UART1 Build the communication among Logic modules, including serial communication module and print module. HY2.0-4P
I2C Connecting microcontrollers and other peripheral devices. HY2.0-4P
BAT Connect with the lithium battery. Connect USC-C port to charge the battery. PH2.0-2P
PICO 2.8-inch HMI Port Pin Number
I2C GP20(SDA), GP21(SCL)
UART0 RX(GP1); TX(GP0)
UART1 RX(GP5); TX(GP4)
GPIO Pins GP0~GP7, GP19~GP21, GP26~GP28
Schematic Diagram
RP2040 and TFT-display wiring pins(SPI)
2
3
Definition in the pins_arduino.h:
Note: Please refer to Get Started With Arduino IDE to install the RP2040 board in the Arduino IDE. After installation, the pins_arduino. h file is located in the Arduino installation directory: ...\Arduino\hardware\rp2040 ...\vaiants rpipico
4
RP2040 and touchscreen wiring pins
image-20240521153232766
Platforms Supported
Arduino SquareLine Studio
Alt text Alt text
FAQS
Resources Download
Hardware
Software
