Crowtail- Vibration Motor
This is a mini vibration motor suitable as a non-audible indicator. When the input is HIGH, the motor will vibrate just like your cell phone on silent mode.
Model: CT0014VM
- Crowtail compatible
- Low power consumption
- High reliability
Dimensions(mm):40.0(L)x20.0(W)x6.9(H)
| Voltage | 3.0 | 5.0 | 5.5 | V |
| Control Mode | Logic Level (When Logic HIGH, the motor is ON. When LOW, the motor is OFF.) | - | ||
| Rated speed | 9000 | rpm | ||
Here is an example showing how to turn on the vibration motor.
1. Plug it onto the Digital port 5 of Crowtail - Base Shield using a Crowtail cable.
2.Plug the Crowtail - Base Shield onto Arduino.
4. Copy and paste code below to a new Arduino sketch, and upload it to your Arduino.
int MoPin = 5; // vibrator connected to digital pin 5
pinMode( MoPin, OUTPUT );
digitalWrite(MoPin, HIGH);
delay(1000);
digitalWrite(MoPin, LOW);
delay(1000);
5.When you upload the code complete,you can see the vibrating motor vibrate at one second intervals.
