Crowbits-Collision Sensor
The collision sensor is a digital input module, it is based on the collision component, which has high sensitivity and can detect any collision movement.
  • Digital input module
  • Easy to use
  • High sensitivity
  • Operating Voltage: 3.3V DC
Usage
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. When you hit the sensor with your hand, the LED behind it will light up.
