Crowduino Mega2560
Introduction¶
Elecrow Crowduino Mega2560 board, almost the same usage and performance with the Arduino Mega2560 but with some difference on the power circuit to ensure the power. Based on the ATmega2560. The Elecrow Mega2560 has 54 digital input/output pins (of which 15 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. With more IOs and larger flash than the Crowduino Uno_SD or Crowduino 328, the Crowduino Mega2560 would be helpful in applications that needs more IOs or larger flash such as in 3D printer projects. It also comes with a type-B USB wire to enable you start the project once you get it in hand.
Model: ACA2560MEG
100% compatible with Arduino Mega
 54 Digital IO
 16 Analog inputs
 14 PWM outputs
 4 Hardware serial ports (UART)
 Compatible with most Arduino Duemilanove and Diecimila Shields
 ICSP Header
 Can be powered through a battery or through a AC to DC adaptor
Specifications¶
Microcontroller: ATmega2560
 Operating Voltage: 5V
 Input Voltage (recommended): 7-12V
 Input Voltage (limits): 6-20V
 Digital I/O Pins: 54 (of which 15 provide PWM output)
 Analog Input Pins: 16
 DC Current per I/O Pin: 40 mA
 DC Current for 3.3V Pin: 50 mA
 Flash Memory: 256 KB of which 8 KB used by bootloader
 SRAM: 8 KB
 EEPROM: 4 KB
 Clock Speed: 16 MHz
 Dimensions(mm):108.0(L)x53.0(W)x14.0(H)
