Crowbits-IR Temperature Sensor
This IR temperature sensor is a non-contact temperature measure model by using the MLX90614, which one is in small size and low cost with a measurement resolution of 0.02℃. Thanks to its low noise amplifier, 17-bit ADC and powerful DSP unit, high accuracy and resolution of the thermometer are achieved.
  • High precision
  • Easy to use
  • Interface Type: I2C
  • Operating Voltage: 3.3V DC
  • Dimensions: 31.5(L)*24.5(W)*13(H)mm
Usage
2. Connect the module to the I2C interface on the Crowbits-UNO board, as shown in the figure:
3. Download the library “I2Cmaster”. Unzip and put it in the libraries file, for example: C:\Program Files (x86)\Arduino\libraries.
4. Upload the following code to the Crowbits-UNO board.
#include <i2cmaster.h>
void setup(){
    Serial.println("Setup...");
    i2c_init(); //Initialise the i2c bus
    PORTC = (1 << PORTC4) | (1 << PORTC5);//enable pullups
void loop(){
    int dev = 0x5A<<1;
    int data_low = 0;
    int data_high = 0;
    int pec = 0;
    i2c_start_wait(dev+I2C_WRITE);
    i2c_write(0x07);
    // read
    i2c_rep_start(dev+I2C_READ);
    data_low = i2c_readAck(); //Read 1 byte and then send ack
    data_high = i2c_readAck(); //Read 1 byte and then send ack
    pec = i2c_readNak();
    i2c_stop();
    //This converts high and low bytes together and processes temperature, MSB is a error bit and is ignored for temps
    double tempFactor = 0.02; // 0.02 degrees per LSB (measurement resolution of the MLX90614)
    double tempData = 0x0000; // zero out the data
    int frac; // data past the decimal point
    // This masks off the error bit of the high byte, then moves it left 8 bits and adds the low byte.
    tempData = (double)(((data_high & 0x007F) << 8) + data_low);
    tempData = (tempData * tempFactor)-0.01;
    float celcius = tempData - 273.15;
    float fahrenheit = (celcius*1.8) + 32;
    Serial.print("Celcius: ");
    Serial.println(celcius);
    Serial.print("Fahrenheit: ");
    Serial.println(fahrenheit);
    delay(1000); // wait a second before printing again
5. After the upload is successful, open the serial port monitor, the baud rate is set to 9600. The serial port will print out temperature information.
