Crowtail- Dual Channel Latching Module
This is a dual-channel latching relay, it does not need continuous power to keep the state, only a rising/falling pulse is needed to change the work state. so the power supply can be cut off without changing the operating state. This module is specifically designed for low power consumption circuit design.
Model: CRT01665R
- Dual Switch
- Low power consumption
- High sensitivity 150mW
- High switching capacity 60W,125VA
- Epoxy sealed for automatic wave soldering and cleaning
Dimensions(mm):50.0(L)x35.0(W)x14.3(H)
| Parameter | Description |
| Operating Voltage | 5V |
| Set/Reset Voltage(Max) | 4.0VDC |
| Switching Voltage(Max) | 35VAC/35VDC |
| Switching Current(Max) | 3A |
| Max Switching Current | 3A |
| Set Time(Latching) | 4.5(max)ms |
| Reset Time(Latching) | 3.5(max)ms |
1.Connect the segment according to the following figure. The com pin is connected to the pin5, NC connected to the GND, NO and connected to the VCC.
2.Relay is connected to the D3, D2 and D4 is connected to the LED.
3.Connect to USB, copy the program and upload it to the board
int relay=3;
int led1=4;
int led2=2;
int relayin1=5;
  pinMode(relay,OUTPUT);
  pinMode(led1,OUTPUT);
  pinMode(led2,OUTPUT);
  pinMode(relayin1,INPUT);
  /* first lift */
   digitalWrite(relay,HIGH);
   /* simply relay  and wait relay response */
   delay(200);
   if(digitalRead(relayin1)==HIGH)
     digitalWrite(led1,HIGH);
     digitalWrite(led2,LOW);
   else
     digitalWrite(led1,LOW);
     digitalWrite(led2,HIGH);
   delay(5000);
   /* second lift */
   digitalWrite(relay,LOW);
   delay(200);
   else
   delay(5000);
4.You can use external power supply or USB power supply.
5. Observe RELAY module NO lights flashing, and green light, proved NO work! Green light; RELAY module on the NC module, NC lights flashing, and red, proved NC end work.
