Crowbits-Light Sensor
The light sensor is an analog input module, it controls your circuit with light. The light sensor measures the light intensity to know how dark or bright the environment is to activate your circuit.
  • Light-control switch
  • Analog input module
  • Operating Voltage: 3.3V DC
Usage
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power.
  • When you place the sensor in a place with strong light, the LED connected behind will not light.
  • when you place the sensor in a place with weak light, the LED connected behind will light up.
