Crowbits-LED (Red Green Yellow)
The LED is a digital output module, it will bring light to your project. Crowbits includes 3 different type of LED colors, all are the same except the color. The kit includes: Red LED, Green LED and Yellow LED.
- 5mm LED
- Digital output module
- Operating Voltage: 3.3V DC
1.You also need to prepare a power module, such as Crowbits-Power Supply, and an input module, such as Crowbits-Touch Sensor.
2.The connection mode is shown in the figure, but the signal feet of the input module and the output module must be connected.
3.Then, turn on the power. When you touch the sensor with your hand, the LED light will light up; Otherwise, the LED will be off.
