ThinkNode M2 Meshtastic (LoRa) Signal Transceiver Powered By ESP32-S3
Elecrow ThinkNode-M2 is a high-performance LoRa signal transceiver. It uses the ESP32-S3 module as the main processor and supports Bluetooth. Users can easily configure and monitor the device through their mobile phones. M2 is pre-installed with Meshtastic firmware and equipped with an SX1262 wireless chip, which can efficiently send and receive LoRa signals to ensure the reliability and stability of communication. In addition, M2 is perfectly compatible with the official Meshtastic App. Users can use the App to implement parameter configuration, message communication, map and location sharing, network status monitoring, data recording and export, and custom settings.
The built-in 1**.3-inch OLED display** can display data and device status in real-time, which is convenient for users to view at any time. Built-in 1000mAh rechargeable battery supports long-term outdoor use. The LoRa antenna supports multiple frequency options to optimize communication performance further. The device adopts a modular design to facilitate embedded integration and custom development.
With integrated LoRa communication technology, ThinkNode-M2 achieves efficient connection and data exchange between devices. Whether in remote areas where cellular networks are not available or in emergencies, M2 can be used as an independent communication tool to provide critical safety assurance. It is also suitable for low-cost information exchange and transmission and reception solutions between communities to meet diverse communication needs.
Self-developed by Elecrow with exclusive design.
Model CIL13002M
ThinkNode-M2-1
  • Thinknode M2’s firmware is adapted to the Meshtastic protocol, it can realize efficient and stable transmission and reception of Lora signals;
  • 1.3-inch OLED display screen for real-time viewing of data and device status;
  • Built-in 1000mAh lithium battery, it can Meet the needs of long-term outdoor use;
  • Adopts modular style, suitable for embedded solution product design;
  • Compatible with the Meshtatic official App. Users can use the App to configure and manage parameters of the M1 device, communicate messages, share maps and locations, monitor network status, record and export data, customize settings, etc.
  • Compact size, easy to carry and durable;
  • External LoRa antenna ensures the stability and efficiency of signal transmission;
Main Processor(ESP32-S3 Module)
CPU/SoC Equipped with high-performance Xtensa 32-bit LX7 dual-core processor, with a main frequency of up to 240MHz
System Memory 512KB SRAM、8M PSRAM
Storage 4M Flash,384KB ROM
Firmware Meshtastic firmware is fully compatible, and the signal is transmitted in LoRa mode
Display
Size 1.3 inch
Display Materials OLED
Resolution 128*64
Driver Chip SH1106
Wireless Communication
WiFi Support 802.11a/b/g/n, 2.4GHz
Bluetooth Bluetooth Low Energy and Bluetooth 5.0
LoRa SX1262 LoRa Transceiver、US 915MHz / EU 868MHz
Hardware
Interface Type-C Interface, IPEX antenna connector (internal), battery connector (internal)
Function LCD display, USB2.0, power management, USB to UART, buzzer, etc.
Button Power button, Function button, Reset button, BOOT button
LED Indicator Power indicator, charging indicator
Other
Power Input 5V/1A, supports USB or lithium battery power supply
Power consumption The maximum working power consumption is about 217mA, and the low power consumption is about 136mA (screen-off state)
Operating Temperature -10~50°C
Storage Temperature -20~60 °C
Relative humidity 10%-95%, @ 40°C (non-condensing)
Size With Case:88.4*46*23mm;Without Case:51.5*37*9.5mm
Shell ABS Plastic
Net weight 30g(Without case);50g(With case)
PWR indicator function
Serial No. Name Print Signal Master Signal Color Description
1 Power indicator PWR IO1_LEDIO6CHGLED IO1 red Ø Device powered on, indicator light is always on;
Ø With lithium battery charging, indicator light (fast blinking); charging is complete, indicator light is always on;
Ø Low battery slow blinking;
Ø Buzzer open alarm, indicator light blinking
Interface/Keypad Functions
ThinkNode-M2-g
Serial No. Name Print Signal Master Signal Functions
1 PWR Button PWR P3.3_IO4_POWER IO4 Short press to turn on/long press 3s to turn off power on, short press to rest the screen
2 FUNCTION Button FUNCTION IO47_FUNCTION IO47 Ø Single-click: scroll down function, switch screen display page
Ø Double-click: send a temporary PING of the device location to the network
Ø Triple-click: trigger the SOS alarm signal (three long and three short), the buzzer sounds, and the indicator light flashes
3 BAT connector BAT / / Access to batteries to power the board
4 Type-C connector USB-IN ESP32_TXD0ESP32_RXD0 IO43IO44 Used for programming and debugging the ESP32 S3 and can also charge the battery with a charging current of 1A
5 screen interface / IO46SCLSDA IO46IO15_SCLIO16_SDA IO46 control screen switches IO15_SCL and IO16_SDA control the screen display
6 RESET Button RESET EN EN Reset ESP32 S3
7 BOOT Button BOOT BOOT IO0 For ESP32 S3 in burn-in mode
8 LORA Antenna Interface LORA_ANT / / Access to 868/915 antenna
GPIO interface function
ThinkNode-M2-h
Serial No. Print Pin Master Signal Functions
1 IO2 IO2 IO2 RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1
2 IO8 IO8 IO8 RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7, SUBSPICS1
3 IO18 IO18 IO18 RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, CLK_OUT3
4 IO19 IO19 IO19 RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D
5 IO20 IO20 IO20 RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+
6 IO38 IO38 IO38 GPIO38, FSPIWP, SUBSPIWP
7 IO39 IO39 IO39 MTCK, GPIO39, CLK_OUT3, SUBSPICS1
8 IO40 IO40 IO40 MTDO, GPIO40, CLK_OUT2
9 IO41 IO41 IO41 MTDI, GPIO41, CLK_OUT1
10 3V3 3V3 / 3.3V供电
11 5V VBUS / 5V供电
12 GND GND / GND
SX1262 Pin
Serial No. Pin Type Master Signal Description
1 SX1262_CS I/O IO10 Used to select the SX1262 chip for communication. When this pin is pulled low, the SX1262 chip is selected for SPI communication.
2 SX1262_SCK I/O IO12 Clock line for SPI interface for synchronized data transfer
3 SX1262_MOSI O IO11 The master device data output line of the SPI interface is used to send data from the microcontroller to the SX1262.
4 SX1262_MISO I IO13 The master device data input line of the SPI interface is used to receive data from the SX1262 to the microcontroller.
5 SX1262_RESET I/O IO21 Reset SX1262 chip. When this pin is pulled low, the SX1262 chip resets.
6 SX1262_BUSY I/O IO14 Indicates if the SX1262 chip is busy. When this pin is high, it indicates that the chip is busy.
7 SX1262_DIO1 I/O IO3 Digital Input/Output Pins
8 SX1262_DIO2 I/O / DIO2 connects to RF_SW, which is set as the control pin of RF switch to control the receiving and transmitting of RF signals
9 SX1262_DIO3 P / DIO3 for TCXO power supply
Usage
Prepare two mobile phones with Meshtastic APP installed and two thinknode M5\M1\M2 devices.
First go to the app store to download and install the Meshtastic APP
ThinkNode-M1-app
Same settings on the receiving side as on the transmitting side
After opening the app, select the top far right and click on Configuration, click on the + in the bottom right corner to find the Meshtastic Bluetooth device.
ThinkNode-M2
ThinkNode-M2-2
2)When the Meshtastic_xxxx device is searched, tap to enter pairing mode.
ThinkNode-M2-4
ThinkNode-M2-3
3)After successful Bluetooth pairing, you need to select a new region at the region again.
ThinkNode-M2-6
4) Set lora frequency, click on the upper right corner of the three points, click on “Radio configurtion”, and then click on “Lora”, scroll down to the ‘Add’ column, in the “Override frequency (Mhz)” at the corresponding frequency written.
lora setting-1
lora setting-1
lora setting-1
5)If two devices want to communicate, they need to join to the same channel, this time you need to select the fourth of the five options above, the other end of the phone needs to join to the same channel by scanning the code or entering the link, the channel can be customized name and so on.
ThinkNode-M2-7
6)After joining, the two devices can now chat in the first screen by selecting Group Chat.
ThinkNode-M2-8
Mutual Messaging Interface.
A-end:
ThinkNode-A-end-5
B-end:
ThinkNode-B-end
1)Open the app, tap Bluetooth on the home page and see the device you want to connect. Click on Pairing.
ios-1
ios-1
ThinkNode-M2-4
ios-3
3)After successful Bluetooth pairing, You need to go to Settings and click on Lora Settings.
ios-1
4) Set lora Region. and then scroll down to set the frequency. consistent with the previous settings for the region. Finally, check ignore MQTT and save.
ios-1
ios-1
ios-1
ios-1
ios-1
5)Go to the information page, select a channel and a QR code will appear, use another device to scan this QR code to enter.
ios-1
ios-1
6)Join and start sending or receiving messages.
ios-1
Github Resources
ThinkNode-M2-Meshtastic-LoRa-Signal-Transceiver-Powered
Burning Firmware
ClickMeshtastic firmware
firmware0
1, Select the corresponding firmware.
firmware1
2, follow the steps to download the firmware.
firmware2
How to buy
Please visit this page to purchase Thinknode M2.
Support
