Crowtail- Buzzer
The buzzer module is for making sound in your project. It sounds when activated by a logic HIGH signal. Connect the buzzer to any of the D(digital) ports of Crowtail- Base Shiled, you can easily make it sounds with setting the related ports to logic HIHG. The buzzer module can be also connected to an analog pluse-width modulation(PWM) output to generate various of tones.
Model: CT0003BU
- Easy to use piezoelectric buzzer
- Standard 3-pin Crowtail Cables
Specifications¶
- Operating Voltage: 5V
- Sound Output: ≥85dB
- Resonant Frequency: 2300±300Hz
- Dimensions(mm):20.0(L)x20.0(W)x9.8(H)
Follow these simple steps to build a Crowtail circuit using the buzzer:
1.Hardware connection Use the Crowtail - Base Shield and connect the Crowtail - Buzzer module to the shield using a designated Crowtail Interface as shown below:
2.Upload the following sample sketch to make the Buzzer make a beeping noise:
#define buzzer 5 //connect Buzzer to digital pin5
 // initialize the digital pin5 as an output.
 pinMode(buzzer, OUTPUT);
 digitalWrite(buzzer, HIGH);   // set the Buzzer on
 delay(500);                  // for 500ms
 digitalWrite(buzzer, LOW);   // set the Buzzer off
 delay(500);
