Mini PC Case With 1.3” OLED Screen For Raspberry Pi 5/Jetson Orin Nano
This Mini PC case is a versatile, DIY enclosure solution designed for Raspberry Pi 5 and Jetson Orin Nano single-board computers. The design concept of this chassis shell is to provide users with an integrated, high-performance, and easy-to-expand hardware platform.
Hardware_Overview_of_Raspberry_Pi_Mini_PC_Case
Compatible Device Raspberry Pi 5/Jetson Nano(Optional)
Screen 1.3” OLED
Power Button Yes
SSD Support Type(Raspberry Pi ) Solid state 2230,2242,2260,2280
Material Aluminum alloy + acrylic
Power Supply(Raspberry Pi) 5V 5A
Power Supply(Jetson Nano) 12V 2A
Fan 3x Cooling Fans
Dimension 120*120*72mm
Use the configuration guide:
Preparation:
Connect the type-c power supply.Raspberry Pi (5V 5A), Jetson Nano (12V 2A).
Press Power to turn on the device:
mini_case_9
Start Configuration
First get the configuration files, now we install git from github and download the configuration files for raspberry pi 5 and jetson:
sudo apt update
sudo apt install -y git
cd ~
git clone https://github.com/Elecrow-RD/Small-Mini-PC-Case.git
Raspberry Pi 5 Configuration:
Go to the Raspberry Pi 5 folder, you can see the relevant configuration files.
cd ~/Small-Mini-PC-Case/Raspberry Pi 5/
mini_case_1
1.Next, copy the different files into the corresponding folders.
mini_case_2
Place rpi5-oled.py in /usr/local/bin/rpi5-oled.py
Place rpi5-oled.service in /etc/systemd/system/rpi5-oled.service
Place shutdown.py in /usr/local/bin/shutdown.py
Place rcshutdown.service in /etc/systemd/system/rcshutdown.service
Place rc.shutdown in /etc/rc.shutdown
2.After placing each of the above five files, start running the command.
Run the command.
sudo chmod +x /usr/local/bin/rpi5-oled.py
sudo apt-get update
sudo apt-get install python3-psutil python3-smbus
sudo systemctl enable rpi5-oled.service
sudo systemctl start rpi5-oled.service
sudo chmod 777 /usr/local/bin/shutdown.py
sudo chmod 777 /etc/systemd/system/rcshutdown.service
sudo chmod 777 /etc/rc.shutdown
sudo systemctl start rcshutdown.service
Modify the contents of config.txt
sudo nano /boot/firmware/config.txt Add "dtoverlay=i2c0" to the last line of config.txt, save it.
sudo nano /boot/firmware/config.txt Add "dtoverlay=i2c0" to the last line of config.txt, save it, and then restart the system.
mini_case_4
Then restart the system.
Jetson Configuration:
Go to the Jetson Orin Nano folder, you can see the relevant configuration files.
mini_case_3
Place jetson-oled.py in /usr/local/bin/jetson-oled.py
Place jetson-oled.service in /etc/systemd/system/jetson-oled.service
2.After placing each of the above two files, start running the command.
Run the command.
sudo chmod +x /usr/local/bin/jetson-oled.py
sudo apt-get update
sudo apt-get install python3-psutil python3-smbus nvme-cli
sudo systemctl enable jetson-oled.service
sudo systemctl start jetson-oled.service
You can see different statuses about your computer on oled. It shows time, temperature, CPU and memory utilization.
mini_case_6
mini_case_5
mini_case_7
mini_case_8
How to buy
Please visit this page to purchase Mini PC Case With 1.3” OLED Screen.
Support
