Crowbits-Expansion
The expansion module is used to expand the signal pins of other modules.
- Expand signal pin
- Operating Voltage: 3.3V DC
- Dimensions: 56(L)*31(W)*13(H)mm
1.Control the motor forward and reverse through 2 buttons
1)You also need to prepare a power module, such as Crowbits-Power Supply. An output module, such as Crowbits-DC Motor. Two input modules, such as Crowbits-Touch Sensor and Crowbits-Switch.
2)The connection mode is shown in the figure, but the signal feet of the input module and the output module must be connected.
3)Turn on the power. You could touch the touch sensor to control the motor to rotate forward, or press the self-locking switch to control the motor to reverse.
