Crowbits-Tilt Switch
The tilt switch is a digital input module, it turns on and off depending on the tilt direction, it can be used to detect the tilt orientation.
- Digital input module
- Easy to use
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. When the tilt switch is tilted, the LED behind it will light up.
