Crowbits-MP3
MP3 is a tiny-size and compact audio module. This module also supports general file systems like FAT16 and FAT32.
  • Easy to use
  • MP3, WMV and WAV audio format supported
  • FAT16, FAT32 files system supported
  • Operating Voltage: 3.3V DC
  • Dimensions: 56(L)*31(W)*13(H)mm
Usage
1.Playing music
1)You also need a power module, such as Crowbits-Power Supply; A SD card containing songs in mp3 format; A 2PIn interface speaker.
2)Insert the SD card into the holder and connect the speaker to the “Speaker seat".
3)Turn the toggle switch on the Crowbits-MP3 board to the "Audio" position.
4)The connection mode is shown in the figure.
5)Turn on the power.
  • You could press the “PLAY” button on the Crowbits-MP3 board, which can play and pause songs.
  • You could press the “UP” button on the Crowbits-MP3 board, which can switch to the next song.
  • You could press the “DOWN” button on the Crowbits-MP3 board, which can switch to the previous song.
  • You could long-press the "UP" button on the Crowbits-MP3 board, which can increase the volume.
  • You could long-press the "DOWN" button on the Crowbits-MP3 board, which can lower the volume.
