Crowtail- thermocouple Sensor
Thermocouples are very sensitive, requiring a good amplifier with a cold - compensation reference. The Crowtail- thermocouple Sensor USES a K type thermocouple Temperature detection, with a Thermistor to detect The ambient Temperature as Temperature compensation. The detectable range of this Sensor is -50-600℃ , and The accuracy is ±(2.0% + 2℃)
Model: CT009559T
Specifications
  • Voltage:3.3 ~ 5V
  • Max power rating at 25℃ :300mW
  • Operating temperature range:-40 ~ +125 ℃
  • he temperature measurement range is (-50 ~ +600℃)
  • Amplifier output voltage range (0 ~ 3.3 V) mv
  • Cold junction compensation (environment temperature measurement)
  • Thermocouple temperature measurement accuracy of + / - 2.0% (+ 2 ℃)
  • Dimensions(mm):40.0(L)x20.0(W)x10.3(H)
Usage
Here is an example to show you how to read temperature information from the sensor.
We need a Crowduino UNO and a Crowtail- thermocouple Sensor.
Hardware Installation
Connect to A4 and A5 on Crowduino. We can use this port to read sensor data.
Let's plug this sensor into the A4 and A5 ports on Crowduino.
Download Code and Upload
You can download the library High_Temp
Then extract the library the Library folder of Arduino, open the demo in examples folder.
Then upload it to your Crowduino.
Then, open your Serial Monitor, you can find the temperature in Celsius here.
K type thermocouple indexing table
As a reference, the following is K type thermocouple indexing table.
Resource
