Crowtail-Rotation Angle Sensor
This rotation Angle sensor using the SV01 series of PSV01A, excellent resistance materials and high reliability wiper achieves 1M cycles,dust-proof construction protects the interior from dust, which maintains stable characteristics.
Model: CRT03345R
- Dust-proof construction protects the interior from dust, which maintains stable characteristics.
- Easy-to-use Crowtail compatible interface
- Supports analog interface
- D formation thru-hole rotor enables selection of any kind of gear shape.
Category: Sensors, Transducers
Family: Position Sensors - Angle, Linear Position Measuring
Series: SV01
For Measuring: Rotary Position
Technology: Resistive
Resistance (Ohms): 10k
Rotation Angle - Electrical, Mechanical: 0°~333.3°
Actuator Type: Hole for Shaft
Linearity: ±2%
Resistance Tolerance: ±30%
Mounting Type: Surface Mount
Termination Style: SMD (SMT) Tab
Operating Temperature: -40°C ~ 85°C
Dimensions(mm):40.0(L)x20.0(W)x6.8(H)
1. Plug it onto the Analog port 0 of Crowtail - Base Shield using a Crowtail cable.
2.Plug the Crowtail - Base Shield onto Arduino.
4.Copy and paste code below to a new Arduino sketch, and upload it to your Arduino.
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
int sensorValue = 0;
// initialize serial communications at 9600 bps:
// read the analog in value:
sensorValue = analogRead(analogInPin);
Serial.println(sensorValue);
delay(1500);
5.When you upload the code complete,you can see the result via the serial port debug window.
