Crowbits-Vibration Motor
The vibration motor is a digital output module, it's similar to the device that makes your cellphone shake when you get a message or call. You can make your projects vibrate with this vibration motor.
- High reliability
- Strengthen Vibration
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an input module, such as Crowbits-Switch.
3. Then, turn on the power. When you press the button of the self-locking switch, the vibration motor will vibrate.
