logo
Elecrow Wiki
PCB Fabricate Service Overview
Initializing search
    • Home
        • Crowduino
        • Crowduino Uno-SD
        • Crowduino M0- SD
        • Crowduino Mega2560
        • ESP8266 IOT Board(Arduino IDE or NodeMCU Lua Programming)
        • 32u4 with A7 GPRS/GSM
        • 32u4 with A9G GPRS/GSM/GPS
        • Smart Pump Shield
        • Screw Shield
        • Crowduino Leonardo
        • Crowduino-Nano-V3.1
        • Elecrow SIMduino UNO+SIM808 GPRS/GSM Board
        • 32u4 with A6 GPRS/GSM
        • Leonardo GPRS/GSM IOT Board v1.1
        • Nano 168(Arduino Compatible)
        • Easy Module Shield for Arduino UNO
        • IO Shield For Arduino Nano
        • Arduino CNC Shield
        • Larduino Mini
        • Crowduino Pro Mini
        • Elecrow ESPduino UNO+ESP8266 Wifi Board
        • ESP32 WIFI/BLE Board v1.0
        • 32u4 with Lora RFM95 IOT Board-868MHz
        • RFM69 Shield
        • 2.4 inch TFT Touch Shield for Arduino
        • 3.5 Inch TFT Color Screen Module 320 X 480 Support Arduino UNO Mega2560
        • TEXT
        • GPRS/GSM Shield v1.0
        • Ehternet Shield
        • WiFi Shield
        • GPS shield
        • 2.8'' TFT Touch Shield
        • Dual Channel H-Bridge Motor Shield
        • Relay Shield
        • CC3000 WiFi Shield
        • USB Host Shield for Arduino
        • Lipower Shield v1.1
        • Mini solar Lipo Charger v1.0
        • USB Hub&Powermanager for RPI Zero v1.0
        • Current/Voltage/Power Monitor HAT for Raspberry Pi
        • Breakout Board for micro:bit IO Expansion Board
        • Rainbow Shield
        • Bluetooth Shield v1.0
        • NFC Shield
        • Motor Shield v1.0
        • Wireless SDshield
        • Motor&Stepper Shield
        • EM Shield
        • CAN-BUS Shield
        • Joystick Shield
        • SIM5360E 3G Shield
        • Speech Interaction board for Raspberry Pi
        • Power over Internet(POE) Hat for Raspberry Pi
        • Uninterruptible Power Supply UPS HAT For Raspberry Pi
        • 4 Channel I2C Motor Shield v1.1
        • XBee shield
        • LCD Keypad Shield
        • Arduino Motor/Stepper/Servo Shield
        • 8-Channel EL Shield
        • SIM808 GPRS/GSM+GPS Shield
        • RTC Data Logger Shield v1.1
        • Capacitive Touch Shield
        • VS1053 MP3 Shield
        • AVR ISP Shield
        • Solderless Protoboard for raspberry pi v1.0
        • IMX219-83 Stereo Camera
        • Binocular Stereo Vision Expansion Board for Raspberry Pi
        • Mbits
        • Pico Shield
        • Crowtail- Base Shield
        • Crowtail- Linear Potentiometer
        • Crowtail- Sound Sensor
        • Crowtail- UV Sensor
        • Crowtail- Thumb Joystick
        • Crowtail- Button
        • Crowtail- LED
        • Crowtail- Buzzer
        • Crowtail- Touch Sensor
        • Crowtail- Tilt Switch
        • Crowtail- I2C LCD
        • Crowtail- Infrared Temperature Sensor
        • Crowtail- Digital Light Sensor
        • Crowtail- GPS
        • Crowtail- One Wire Waterproof Temperature Sensor
        • Crowtail- Dust Sensor
        • Crowtail- Gas Sensor(MQ2)
        • Crowtail- ES08A Mini Servo
        • Crowtail- PIR Motion Sensor
        • Crowtail- 3-Axis Digital Compass
        • Crowtail- SIM808
        • Crowtail- Microwave sensor
        • Crowtail- Dry-Reed Relay
        • Crowtail- Pulse Sensor
        • Crowtail- Air Quality Sensor
        • Crowtail- AM2302 Humidity&Temperature Sensor
        • Crowtail- Solid-State Relay
        • Crowtail- I2C Motor Driver
        • Crowtail- LED Bar
        • Crowtail- Protoboard
        • Crowtail- SPDT Relay
        • Crowtail- Super Bright
        • Crowtail-Rotation Angle Sensor
        • Crowtail- Haptic Motor
        • Crowtail- TPL5111 Reset Enable Timer
        • Crowtail- MEMS Microphone
        • Crowtail- LiPo Fuel Gauge
        • Crowtail- Mini PIR Motion Sensor
        • Crowtail- BMP280 Barometer Sensor
        • Crowtail- Strain Gauge sensor
        • Crowtail- VL53L0X Laser Ranging Sensor
        • Crowtail-Digital-Programmable-Potentiometer
        • Crowtail-Weight Sensor
        • Crowtail- MPU6050 Accelerometer & Gyro
        • Crowtail- Vibration Motor
        • Crowtail- Relay
        • Crowtail- Moisture Sensor
        • Crowtail- Light Sensor
        • Crowtail- Hall Sensor
        • Crowtail- Encoder
        • Crowtail- IR Reflective Sensor
        • Crowtail- Temperature& Humidity Sensor
        • Crowtail- Analog Gyro
        • Crowtail- MOSFET
        • Crowtail- Flame Sensor
        • Crowtail- Rotary Angle Sensor
        • Crowtail-Nano Base Board
        • Crowtail- Fingerprint Sensor
        • Crowtail- Gas Sensor(MQ5)
        • Crowtail- Adjustable Infrared Sensor
        • Crowtail- 3-Axis Digital Gyro
        • Crowtail- Gas Sensor(MQ9)
        • Crowtail- I2C Color Sensor
        • Crowtail- Collision Sensor
        • Crowtail- 9G Servo
        • Crowtail- Magnetic Switch
        • Crowtail- Electromagnet
        • Crowtail- Vibration Sensor
        • Crowtail- Analog Grayscale Sensor
        • Crowtail- Switch
        • Crowtail- I2C EEPROM
        • Crowtail- Recorder
        • Crowtail- Speaker
        • Crowtail- MP3
        • Crowtail- Screw Terminal
        • Crowtail- I2C Hub
        • Crowtail- UV sensor(GUVA- S12SD 2.0
        • Crowtail- PH Sensor
        • Crowtail- NFC
        • Crowtail- Logic Block
        • Crowtail- 1.3 Inch OLED v1.0
        • Crowtail- CurrentPower Sensor
        • Crowtail-LED Matrix
        • Crowtail- DHT20
        • Crowtail- IMU 10DOF
        • Crowtail- HTU21D Humidity& Temperature Sensor
        • Crowtail-Knock Sensor
        • Crowtail-GP02
        • Crowtail- BMP180 Barometer
        • Crowtail- Blutooth Low Energy Module
        • Crowtail- Thermistor Temperaturen Sensor
        • Crowtail- RTC
        • Crowtail- Serial Wifi
        • Crowtail- IR Emitter
        • Crowtail- IR Receiver
        • Crowtail- Current Sensor
        • Crowtail- RGB-LED
        • Crowtail- OLED
        • Crowtail- Gas Sensor(MQ3)
        • Crowtail- Water Sensor
        • Crowtail- 3-Axis Digital Accelerometer
        • Crowtail- Laser Pointer
        • Crowtail- Ultrasonic Ranging Sensor
        • Crowtail- 80cm Infrared Proximity Sensor
        • Crowtail- 4-Digit Display
        • Crowtail- Current Sensor Kit
        • Crowtail- Extend board for Connection
        • Crowtail- Photo Electric Counter
        • Crowtail- Electricity Sensor
        • Crowtail- Voltage Sensor
        • Crowtail- thermocouple Sensor
        • Crowtail- Gesture
        • Crowtail- G1/4" Water Flow Sensor
        • Crowtail- G1/2" Water Flow Sensor
        • Crowtail- G3/4" Water Flow Sensor
        • Crowtail- G1" Water Flow Sensor
        • Crowtail- Non-contact liquid level sensor
        • Crowtail- Serial Camera
        • Crowtail- Luminance sensor
        • Crowtail- Dual Channel Latching Module
        • Crowtail- Temperature Sensor TMP102
        • Crowtail- 315Mhz RF Receiver with Transmitter
        • Crowtail- MAX30105 Particle Sensor
        • Crowtail-Capacitive Moisture V2.0
        • Crowtail- Stackable Shield for Raspberry Pi 2.0
        • Crowtail- Motor Base Shield
        • Crowtail- A6 GPRS/GSM Module
        • Crowtail- WIFI Module
        • Crowtail- LoRa RA-08H
        • Crowtail- DWM1000 UWB(Ultra Wide Band
        • Crowtail- 4G SIM-A7670E
        • Crowbits-LED (Red Green Yellow)
        • Crowbits-Buzzer
        • Crowbits-Relay
        • Crowbits-Bright LED
        • Crowbits-Vibration Motor
        • Crowbits-Electromagnet
        • Crowbits-DC Motor
        • Crowbits-MOSFET
        • Crowbits-MP3
        • Crowbits-Recorder
        • Crowbits-TPL5111 Timer
        • Crowbits-Vibration Sensor
        • Crowbits-Magnetic Switch
        • Crowbits-Water Sensor
        • Crowbits-Reaction
        • Crowbits-Touch Sensor
        • Crowbits-PIR Sensor
        • Crowbits-Tilt Switch
        • Crowbits-Button
        • Crowbits-Switch
        • Crowbits-Flame Sensor
        • Crowbits-Collision Sensor
        • Crowbits-IR Reflective Sensor
        • Crowbits-Photo Electric Counter
        • Crowbits-Hall Sensor
        • Crowbits-Microphone
        • Crowbits-Potentiometer
        • Crowbits-Light Sensor
        • Crowbits-Pressure Sensor
        • Crowbits-Servo Control
        • Crowbits-Linear Potentiometer
        • Crowbits-Terminal
        • Crowbits-315Mhz Emitter
        • Crowbits-Expansion
        • Crowbits-Protoboard
        • Crowbits-Power Supply(S
        • Crowbits-Trigger Delay
        • Crowbits-Logic AND
        • Crowbits-Logic OR
        • Crowbits-Logic NOT
        • Crowbits-Logic Input
        • Crowbits-315MHz Controller
        • Crowbits-IR Emitter
        • Crowbits-RGB LED
        • Crowbits-LED Bar
        • Crowbits-315Mhz Receiver
        • Crowbits-IR Receiver
        • Crowbits-DHT11 Sensor
        • Crowbits-Gas Sensor
        • Crowbits-Encoder
        • Crowbits-Pulse Sensor
        • Crowbits-Air Quality Sensor
        • Crowbits-Grayscale Sensor
        • Crowbits-UV Sensor
        • Crowbits-Ultrasonic Ranging Sensor
        • Crowbits-Thumb Joystick
        • Crowbits-Digital Potentiometer
        • Crowbits-Keyboard
        • Crowbits-Voltage Sensor
        • Crowbits-CurrentPower Sensor
        • Crowbits-IR Temperature Sensor
        • Crowbits-NFC
        • Crowbits-Barometer Sensor
        • Crowbits-Digital Light Sensor
        • Crowbits-LED Matrix
        • Crowbits-RGB Matrix
        • Crowbits-HTU21D Humiture Sensor
        • Crowbits-Laser Ranging Sensor
        • Crowbits-Color Sensor
        • Crowbits-RTC
        • Crowbits-Gesture Sensor
        • Crowbits-OLED
        • Crowbits-EEPROM
        • Crowbits-Digital Display
        • Crowbits-WiFi
        • Crowbits-GPS
        • Crowbits-2G Module
        • Crowbits-Microbit Compatible
        • Crowbits-UNO
        • Crowbits-80cm Infrared Proximity Sensor
        • Crowbits-Adjustable Infrared Sensor
        • Crowbits-9G Servo
        • Crowbits-G1-4 Water Flow Sensor
        • Crowbits-Non-Contact Liquid Level Sensor
        • Crowbits-One Wire Waterproof Temperature Sensor
        • Crowbits-Moisture Sensor
        • Crowbits-DHT20
        • Temperature & Humidity Sensor
        • PIR Motion Sensor
        • Tiny RTC
        • Adjustable Infrared Sensor Switch
        • Triple Axis Magnetometer Breakout
        • Ultrasonic Ranging Sensor Module
        • ACS712 Current Sensor- 5A
        • 1-Axis Analog Gyro Module-ENC03
        • 2-Axis Analog Gyro Module-ENC03
        • Strain Gauge Module
        • 4MM Inductive Metal Proximity Sensor
        • Fingerprint Sensor
        • Infrared Thermometer MLX90614 Breakout Board
        • Luminosity Sensor- TSL2561 Breakout
        • HC-SR505 Mini PIR Motion Sensor
        • Digital light Sensor
        • Photosensor- Short Range
        • Photosensor- Long Range
        • One Wire Waterproof Temperature Sensor
        • Accelerometer Breakout-MMA7361
        • MPU-6050
        • 3-Axis Analog Gyro Module-ENC03
        • Weight Sensor Scales Kit- 20KG
        • Non-invasive AC Current Sensor-100A
        • TCS3200 Colour Sensor Module
        • Analog CO/Combustible Gas Sensor(MQ9
        • UV Sensor ML8511
        • Barometer Sensor
        • IMU 10DOF LSM303D+L3GD20 +BMP180
        • Encoder Gear Motor-25MM 95RPM
        • Weight Sensor Amplifier-HX711
        • DHT11
        • Tiny Adjustable Infrared Sensor Switch
        • Serial JPG Camera
        • Dust Sensor- DSM501A
        • Dust Sensor- GP2Y1010AU0F
        • Pulse Sensor
        • Sound Recorder- ISD1760
        • 80cm Infrared Proximity Sensor-GP2Y0A21YK0F
        • Analog Smoke/LPG/CO Gas Sensor(MQ2
        • ENC28J60 Ethernet Module
        • UV Sensor Module-UVM30A
        • APM2.5 Airspeed Breakout Board MPXV7002DP
        • Soil Moisture Sensor
        • Rectangle capacitive fingerprint scanner breathing light fingerprint AS608 sensor
        • 1019DRound fingerprint recognition sensor module ID809
        • 315/433Mhz RF Link Kit
        • NRF24L01+PA+LNA Wireless Module
        • Smart car with ESP32-CAM Board
        • 2.4G Wireless nRF24L01
        • Serial Port Bluetooth Module
        • Wireless Charger& Receiver
        • 433MHz RF Transceiver CC1101 Module
        • Serial WIFI Transceiver Module ESP8266
        • ESP32S WIFI BLE Board
        • CrowBot-BOLT Programmable Smart Robot Car STEAM Robot Kit
        • Lora RFM95 IOT Board for RPI
        • SIM7670 4G Module with Mini PCIe Interface
        • Wireless Module for Wi-Fi HaLow
        • ESP32 Wi-Fi HaLow Module with 2MP Camera 32Mbps High Speed Long-distance transmission 915MHz
        • 0.96" OLED 128x64-Blue
        • I2C 0.96" OLED 128x64-Blue
        • 1.44'' 128x128 TFT LCD with SPI Interface
        • 3.5 Inch 480x320 TFT Display with Touch Screen for Raspberry Pi
        • 3.95 Inch TFT Display for Raspberry Pi
        • RC070M 7 inch 1024 X 600 Touch Screen Display with 720P Camera for Raspberry Pi/ MacBook Pro./ Windows 10
        • RR070 7 Inch 1024x600 HDMI/VGA/AV Display for Raspberry Pi B/B+/2B/3B
        • SF101C 10.1 inch 1280*800 IPS HDMI LCD Display(with case) for Raspberry Pi
        • SF116 11.6 Inch 1920x1080 HDMI 1080P LED Display for Raspberry Pi
        • 2.9 inch e-Paper Module Three Color-Red Black White
        • 1.3 inch IPS TFT LCD Display ST7789
        • Elecrow 10.1 inch Display IPS 1280x800 Acrylic Case Touch Screen Compatible with Raspberry Pi Jetson Nano PC
        • 5.0 Inch HDMI-Compatible Display for Raspberry Pi Compatible with Jetson Nano, Beaglebone
        • I2C LCD2004(Yellow
        • I2C LCD1602(Blue)
        • WS2812 RGB LED Ring
        • HDMI Interface 5 Inch 800x480 TFT Display
        • 4 Inch HD 480x320 TFT Display with Touch Screen for Rapberry Pi
        • RC050 5 inch HDMI 800 x 480 Capacitive Touch LCD Display for Raspberry Pi/ PC/ SONY PS4
        • ELECROW 11.6 Inch 1080P IPS 1920x1080 Monitor with Built-in Speaker for Raspberry Pi PS4 XBOX Windows without touch function
        • ELECROW 11.6 Inch 1080P IPS 1920x1080 Monitor with Built-in Speaker for Raspberry Pi PS4 XBOX Windows with touch function
        • SF101 10.1 Inch 1920x1080 Display HDMI VGA IPS PS3 PS4 Gaming Screen
        • SF101R 10.1 Inch Portable HD Display for Raspberry Pi 3
        • SF133 13.3 Inch IPS 1920X1080 Monitor Dual HDMI PortablePS3 PS4 Gaming Screen
        • 3.5inch 480x320 MCU SPI Serial TFT LCD Module Display
        • Meteor Screen 10.1" IPS Touch Screen (with RGB Animated light)
        • 1602 LCD Display Module
        • 16x16 LED Display Module
        • 7 Inch 1024*600 HDMI LCD Display with Touch Screen
        • 7 Inch 1024x600 TFT Display for Raspberry Pi B+ Pcduino Banana Pi
        • Elecrow RR040I 4 inch HD 800x480 Resolution IPS TFT Touch Screen Display for Raspberry Pi
        • 7 Inch TFT Display for Raspberry Pi B+ Banana Pi BB BLACK
        • SF133M 13.3 inch 1920 x 1080 HDMI Portable Display for Raspberry Pi/ PS4/ XBOX/ NS
        • RR040I 4 inch HD 800x480 Resolution IPS TFT Touch Screen Display for Raspberry Pi
        • GC1016 10.1" TFT-LCD Monitor 1280*800 Color Screen with AV1 VGA HDMI BNC USB Input Built-in Speaker
        • 2 inch IPS Module
        • Elecrow 10.1 Inch Touchscreen 1280x800 IPS TFT LCD Monitor Kit
        • 8 inch Touchscreen IPS Display 1280x800 Small Portable Monitor Compatible with Raspberry Pi 540043 Win 111087 Jetson Nano
        • 2.4 inch 320x240 SPI Serial TFT LCD Module Display With Driver IC ILI9341|With Touch Function
        • 2.8 inch 320x240 SPI Serial TFT LCD Module Display With Driver IC ILI9341|With Touch Function
        • 3.5 Inch 480*320 SPI TFT LCD Module with ILI9488 Driver|With Touch Function
        • 4.0 Inch 480*320 SPI TFT LCD Module with ST7796 Driver|With Touch Function
        • 2.8” 240x320 ESP32 LCD Touch Display | With WiFi and BT/BLE
        • 3.2” 240x320 ESP32 LCD Touch Display | With WiFi and BT/BLE
        • 3.5” 320x480 ESP32 LCD Touch Display | With WiFi and BT/BLE
        • 3.5” ESP32 S3 Display with 320x480 Capacitive IPS Touch Panel
        • 4.3” ESP32 S3 Touch Display 480272 Resisitive Touch With WiFi and BLE
        • 5.0” ESP32 S3 IPS Display 800x480 Capacitive Touchscreen Supports WiFi Bluetooth With Speaker Interface
        • 2.8-inch IPS SPI LCD Capacitive Touch Display Module With ILI9341 Driver - 240x320 Resolution, Arduino Compatible
        • 3.5-inch IPS SPI LCD Capacitive Touch Display Module With ST7796 Driver - 320x480 Resolution, Arduino Compatible
        • 4.0-inch Capacitive Touch SPI LCD Display Module With ST7796 Driver - 320x480 Resolution, Arduino Compatible
        • 4.3” 800*480 IPS Display 16BIT Parallel LCD Module| SSD1963 Driver |Capacitive Touch
        • 5.0” 800*480 IPS Display 16BIT Parallel LCD Module| SSD1963 Driver |Capacitive Touch
        • 7.0” 800*480 Display 16BIT Parallel LCD Module| SSD1963 Driver |Capacitive Touch
        • 2.8inch TFT Screen 320*240 Touch Display for Arduino, Mega|ILI9341 Driver|Plug & Play
        • 3.95 inch TFT Screen 480*320 Touch Display for Arduino, Mega | ST7796S Driver | Plug & Play
        • 5inch IPS HD Display-C 1024*600 Touch Screen Compatible with Raspberry Pi/BB Black, etc
        • 5inch HD Touch Display-D 1024*600 IPS Screen Compatible with Raspberry Pi/BB Black, etc
        • 7inch IPS HD Touch Screen-D 1024*600 HD Monitor Compatible with Raspberry Pi/BB Black, etc
        • 10.1 inch_HD Touchscreen 1520*720 IPS Screen Designed for Raspberry Pi 5 point Capacitive Touch
        • Wizee HMI touch display
        • CrowPanel HMI Display Wiki Content
        • CrowPanel ESP32 HMI Wiki Content
        • ESP Terminal with 3.5inch RGB Capacitive Touch Display
        • ESP Terminal with 3.5inch SPI Capacitive Touch Display
        • CrowPanel ESP32 HMI 2.4-inch Display
        • CrowPanel ESP32 HMI 2.8-inch Display
        • CrowPanel ESP32 HMI 3.5-inch Display
        • CrowPanel ESP32 HMI 4.3-inch Display
        • CrowPanel ESP32 HMI 5.0-inch Display
        • CrowPanel ESP32 HMI 7.0-inch Display
        • 2 PACK 2.4-inch ESP32 Solo Miner LCD Display
        • 2 PACK 2.8-inch ESP32 Solo Miner LCD Display
        • CrowPanel PICO HMI 2.4'' Display
        • CrowPanel PICO HMI 2.8'' Display
        • CrowPanel PICO HMI 3.5'' Display
        • CrowPanel PICO HMI 4.3'' Display
        • CrowPanel ESP32 1.28-inch Round Display
        • Pi Terminal
        • CrowPanel ESP32 E-Paper HMI 1.54-inch Display
        • CrowPanel ESP32 E-Paper HMI 2.13-inch Display
        • CrowPanel ESP32 E-Paper HMI 2.9-inch Display
        • CrowPanel ESP32 E-Paper HMI 3.7-inch Display
        • CrowPanel ESP32 E-Paper HMI 4.2-inch Display
        • CrowPanel ESP32 E-Paper HMI 5.79-inch Display
        • CrowPanel Advance 2.4-HMI ESP32 AI Display
        • CrowPanel Advance 2.8-HMI ESP32 AI Display
        • CrowPanel Advance 3.5-HMI ESP32 AI Display
        • CrowPanel Advance 4.3-HMI ESP32 AI Display
        • CrowPanel Advance 5.0-HMI ESP32 AI Display
        • CrowPanel Advance 7.0-HMI ESP32 AI Display
        • CrowPanel 1.28inch-HMI ESP32 Rotary Display 240*240 IPS Round Touch Knob Screen
        • CrowPanel 1.46-inch-HMI ESP32 Rotary Display 360*360 IPS Round Touch Knob Screen
        • CrowPanel 2.1inch-HMI ESP32 Rotary Display 480*480 IPS Round Touch Knob Screen
        • CrowPanel 2.01inch HMI ESP32 Watch Display 240*296 IPS Touch Screen WithMicrophone
        • CrowPanel HMI ESP32 Rotary Display ESPHome course
        • CrowPanel Advanced 5inch ESP32-P4 HMI AI Display 800*480 IPS Touch Screen with WiFi 6
        • CrowPanel Advanced 7inch |ESP32-P4 HMI AI Display 1024*600 IPS Touch Screen with WiFi 6 Compatible with Arduino/LVGL
        • CrowPanel Advanced 9inch |ESP32-P4 HMI AI Display 1024*600 IPS Touch Screen with WiFi 6 Compatible with Arduino/LVGL
        • CrowPanel Advanced 10.1inch |ESP32-P4 HMI AI Display 1024*600 IPS Touch Screen with WiFi 6 Compatible with Arduino/LVGL
        • 10.1 Smart Home Control Panel for Home Assistant
        • CrowVision 11.6'' Capacitive Touch Screen Portable HD 1366*768 IPS LCD Display
        • CrowVision 7.0" Touch Screen Capacitive Portable HDMI-compatible 1024*600 IPS LCD Monitor
        • CrowView Yoga 15.6" Dual Screen Portable Monitor |360° Foldable IPS Laptop Extender for Gaming and Mobile Office
        • CrowView Note 15.6"
        • CrowView Note 14 for Arduino UNO Q with Camera Kit
        • Mechanical_Keyboard_ESP32-S3
        • Elecrow Services
        • PCB Fabricate Service Overview
        • Q&A for PCB service
        • Export gerber files from Eagle
        • Export gerber files from Proteus_ARES
        • Breadboard Power Supply
        • ULN2003 Stepper Motor Driver
        • Lipo Charger v1.0
        • LED matrix kit
        • RTD2556 Driver Board/Controller Board Kit
        • devDuino Sensor Node V1.3 (ATmega 328)
        • Adjustable Integrated DC-DC Module- LM2596S
        • Transparent Acrylic Switches Tester Collection
        • Crazepony MINI Quadcopter
        • Cooperator Designer
        • Drop Shipping
        • Products Wiki
        • CrowPi-2
        • CrowPi-L
        • CrowPi-3
        • PICO W5 RP2040 Dev Board
        • Elecrow RP2350 Pico W5 Board
        • Mini PC Case With 1.3” OLED Screen For Raspberry Pi 5/Jetson Orin Nano
        • PiTower Gen 2 Mini PC_Case with 2.8 IPS Screen Dual SSD Slot Designed for Raspberry Pi 5
        • Pi Power M.2 NVMe&PoE+ Hat for Raspberry Pi 5 Support M.2 NVMe SSDs 2230/2242/2260/2280
        • Image Burning Method
        • Lora RA-08H Development Board
        • Lora RA-08H Node Board
        • Lora Basic Gateway Module
        • LR1302 LoRaWAN Gateway Module
        • LR1302 LoRaWAN HAT for RPI_PRD
        • LR1262 LoRaWAN Node Module
        • LR1262 Node Board LoRaWan Node Module for Long Range Communication
        • LoRaWAN LR1262 Development Board Integrated RP2040 with 1.8" LCD for Long Range Communication
        • Nrf52840 AT Instruction Description Documentation
        • Elecrow nRFLR1110 Wireless Transceiver Module
        • Elecrow nRFLR1121 Wireless Transceiver Module
        • Elecrow nRFLR1262 Wireless Transceiver Module
        • Elecrow nRFLRCC68 Wireless Transceiver Module
        • Elecrow lr2021 lora module
        • LoRa Node Expansion Board nRFLR1121 Integrates nRF52840 for Long Range Communication Support 868915 Mhz
        • LoRa Node Expansion Board nRFLR1110 Integrates nRF52840 for Long Range Communication Support GNSS Position
        • ThinkNode M1 Meshtastic (LoRa) Signal Transceiver Powered By nRF52840 with 1.54" Screen Support GPS-With Case-868 MHz
        • ThinkNode M2 Meshtastic (LoRa) Signal Transceiver Powered By ESP32-S3 with 1.3” OLED Display-Without Case
        • LR1262 Long-Range LoRa Wireless Transceiver Module | Ultra-Low Power | IoT/Industrial
        • LRCC68 Long-Range LoRa Wireless Transceiver Module | Ultra-Low Power | IoT/Industrial
        • ThinkNode G1 Indoor 8 Channels LoRaWAN Gateway Powered By SX1302 Chip
        • ThinkNode G3-Single Channel LoRaWAN Gateway ESP32-S3 Chip Smart Home, Smart IoT Solutions
        • ThinkNode G4 Wi-Fi HaLow Gateway Support Wi-Fi HaLow Ethernet Connections
        • ThinkNode M3 Meshtastic Tracker With GPS/WiFi/BLE function For Indoor and Outdoor Positioning
        • ThinkNode M3 LoRaWan Tracker With GPS/WiFi/BLE function For Indoor and Outdoor Positioning
        • ThinkNode-M4 Power Bank LoRa Device with Meshtastic Function Powered By nRF52840
        • ThinkNode M4 Power Bank LoRa Device with LoRa Tracker Function Powered By nRF52840
        • ThinkNode M5 Meshtastic (LoRa) Signal Transceiver |ESP32-S3
        • ThinkNode M6 Outdoor Solar Power for Meshtastic, Powered By nRF52840 Supports GPS
        • ThinkNode M6 Outdoor Solar Power for LoRa, Powered By nRF52840 Supports GPS
        • ThinkNode M7 Meshtastic Wireless Communication Gateway
        • ThinkNode M7 LoRaWAN Wireless Communication Gateway Support PoE Power
        • ThinkNode M9 MeshCore Communication Terminal with Full Keyboard
        • Meshstick USB To SPI SX1262 TCXO LoRa USB Stick
        • ThinkNode M9 Meshtastic Communication Terminal with Full Keyboard
        • All-in-one Starter Common Board Kit for Arduino
        • All-in-one Starter Kit for Pico 2
        • All-in-one Starter Kit for Micro:bit with Common Board design:13 Modules and 21 Lessons
        • All-in-one Starter Kit for ESP32-P4 with Common Board design
        • AI Camera Development Board Vision Sensor Board Powered By ESP32
        • AI Panda ChatBot
        • AI Starter Kit for Jetson
        • 26 in 1 Learning Kit for Arduino UNO_R4 with 26 lessons Support WiFi and BLE
        • All in one Starter Kit for Arduino NANO R4 with 20 lessons and 16 modules
    • Tutorials
    • Back to Community
    Please Visit this page to order the PCBs http://www.elecrow.com/services-c-73.html
    PCB Material FR4 datasheet File:PCB material FR-4 info.pdf
    PCB order steps and PCB fabrication specification
    Q&A for PCB service
    Previous
    Elecrow Services
    Next
    Q&A for PCB service
    Made with Material for MkDocs
