Crowbits-Buzzer
The buzzer is a digital output module, it makes a sound when receives the signal. Typical uses of buzzer include alarm devices, timers, etc.
- Easy to use the piezoelectric buzzer
- Digital output module
- Operating Voltage: 3.3V DC
- Oscillation Frequency: (2.7 ±0.3) KHz
- Sound Pressure Level: ≥80dB
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an input module, such as Crowbits-Switch.
3. Then, turn on the power, the buzzer will beep when you press the self-locking switch.
Note: Please tear off the paper on the buzzer when you want to use it for the buzzer to work properly. The paper on top is in order to protect it while shipping and transporting.
