Crowbits-DHT20
DHT20 is an intelligent temperature and humidity sensor module that can convert temperature and humidity into electrical signals to easily measure temperature and humidity. The module is equipped with a newly designed ASIC dedicated chip, an improved MEMS semiconductor capacitive humidity sensor element and a standard temperature sensor element. After comprehensive improvement, DHT20 reduces power consumption and cost, while greatly improving measurement accuracy, power supply voltage, measurement range, response time, stability, etc.; it has the characteristics of no calibration, low power consumption, high accuracy, and high stability. Using fully calibrated digital I2C communication interface, it has fast response, strong anti-interference ability and high cost performance.
Technical specifications¶
Working voltage: DC2.2V+5.5V
Measuring range
- Humidity: 0%-100% RH
- Temperature: -40~80°C
Error range
- Humidity: ±3% RH
- Temperature: ±0.5°C
Resolution
- Humidity: ±0.024% RH
- Temperature: 0.01°C
Response time
- Humidity: τ63% condition is less than 8 seconds
- Temperature: τ63% condition mini5 seconds, max30 seconds
Interface type: I2C
Size: 31.5 (L)*24.5(W)*13(H)mm
Application scenarios¶
Test environment temperature and humidity information
The following sketch demonstrates a simple application
2. Connect the module to the A4 and A5 interface on the Crowbits-UNO board, as shown in the figure below:
3. Download the Crowbit-DHT20 software file and unzip it and place it in the libraries folder of the Arduino IDE. Run Arduino.exe, Open path: Crowtail-DHT20 --> examples --> DHT20 --> DHT20.ino
#include <DHT20.h>
* @brief Construct the function
* @param pWire IC bus pointer object and construction device, can both pass or not pass parameters, Wire in default.
* @param address Chip IIC address, 0x38 in default.
DHT20 dht20;
Serial.begin(115200);
//Initialize sensor
while(dht20.begin())
Serial.println("Initialize sensor failed");
delay(1000);
//Get ambient temperature
Serial.print("temperature:"); Serial.print(dht20.getTemperature());Serial.print("℃");
//Get relative humidity
Serial.print(" humidity:"); Serial.print(dht20.getHumidity()*100);Serial.println(" %RH");
delay(1000);
4. Upload it to your Crowbits-UNO board, open the COM serial port, select 115200 for the baud rate at the bottom right, and the monitor displays the current environmental temperature and relative humidity information.
