ThinkNode M3 Meshtastic Tracker With GPS/WiFi/BLE function For Indoor and Outdoor Positioning
Model ILO13903D
thinknode_m3_meshtastic_tracker
Hardware Overview
hardware_overview_of_Thinknode_m3_tracker
Usage
Button Function Guide:
ThinkNode-M3-009
Button operations and buzzer sounds:
Features Button Controls Buzzer and LED Effects Other
Power On Press briefly for 1 second The buzzer will sound, and the red indicator light will stay on for 5 seconds before the blue indicator light turns on (searching for Bluetooth).
Power Off Press and hold for 5 seconds The buzzer beeps
Send and receive data When LoRa receives data, the buzzer sounds for 15 seconds; when LoRa transmits data, there is no sound. The green light will flash; press the button to turn it off, and the device will beep once.
Update Press and hold for 15 seconds enter firmware update mode.
example :
Conducting hiking expeditions and scientific sampling activities in remote mountain valleys. The team utilised nodes equipped with ThinkNode M4 devices as Meshtastic relays to facilitate information transmission and location sharing. The extended battery life provided by the large-capacity batteries ensured reliable communication support for the team.
ThinkNode-M4_003
The following outlines the procedure for transmitting signals to the designated relay point.
How to obtain the app:
1: Visit the Google Play Store (https://play.google.com/), search for ‘meshtastic’, locate the app, and download it for installation.
ThinkNode-M3-0000
2: Visit the official Meshtastic website (https://meshtastic.org/downloads/) and download the software.
ThinkNode-M3-0001
ThinkNode-M3-0000
Before use, press and hold the power button for 1 seconds to switch on:
ThinkNode-M3-009
1 Android App Usage Guide
2 iOS App Usage Guide
Prepare two mobile phones with Meshtastic APP installed and two thinknode M5\M1\M2\M3 devices.
Android App(Version 2.6.30)
First go to the app store to download and install the Meshtastic APP
ThinkNode-M3-000
Meshtastic APP Usage:
Same settings on the receiving side as on the transmitting side
After opening the application, tap ‘Scan’ and select the corresponding Meshtastic device to connect.
thinknode-M3-001
When the Meshtastic_xxxx device is searched, tap to enter pairing mode.
Enter this code(123456) on your cell phone(The default code for the ThinkNode M3 is 123456.).
thinknode-M3-002
Set LoRa frequency: Tap the settings icon, select ‘Radio Configuration’, then tap the ‘LoRa’ option. Scroll down to the “Add” column and enter the required value in the ‘Coverage Frequency (MHz)’ field corresponding to the desired frequency.
thinknode-M3-008
thinknode_M3-07
After joining, the two devices can now chat in the first screen by selecting Group Chat.
thinknode_M3-02
iOS App:
1)Open the app, tap Bluetooth on the home page and see the device you want to connect. Click on Pairing.
ios-1
ios-1
2)When the Meshtastic_xxxx device is searched, tap to enter pairing mode.
ios-3
3)After successful Bluetooth pairing, You need to go to Settings and click on Lora Settings.
ios-1
4) Set lora Region. and then scroll down to set the frequency. consistent with the previous settings for the region. Finally, check ignore MQTT and save.
ios-1
ios-1
ios-1
ios-1
5)Go to the information page, select a channel and a QR code will appear, use another device to scan this QR code to enter.
ios-1
ios-1
6)Join and start sending or receiving messages.
ios-1
Burning Firmware
Press and hold the button for 15 seconds to enter firmware update mode.
Click Meshtastic firmware to visit the Meshtastic firmware flashing website.
ThinkNode-meshtastic_001
1,Select the corresponding firmware.
ThinkNode-meshtastic_002
2, follow the steps to download the firmware.
ThinkNode-meshtastic_003
How to buy
Please visit this page to purchase ThinkNode M3 Meshtastic Tracker.
Support
