Crowtail-Nano Base Board
The Crowtail- nano Base Shield plugs into Crowduino Nano module and play the foundation of the Crowtail system. ALL I/O ports of the Crowduino Nano are exposed and adapted into Crowtail connectors which include digital I/O,analog I/O,and specialized ports(I2C,UART).
Model: CT0054NBB
- Compatible with Crowduino Nano Module.
- 3 Digital connectors (D2-D4)
- 3 Analog connectors (A0-A2)
- 1 I2C sockets
- NO SPI socket
- UART connector
- Stacking connectors
- Two power supply mode
- Dimensions(mm):61.6(L)x20.0(W)x18.2(H)
Interface Function¶
The purpose of the base shield is to allow easy connection of any microprocessor input and output pins to the Crowtail units. For a more detailed examination of the Base Board, please refer to the following diagram:
D port:Digital I/O port.
A port:Analog I/O port.
U port:UART port.
I port:IIC port.
This is a pecular interface logo of all the Crowtail products. It may you easy to differentiate which module is connect to the digital port or other port.
