1.3 inch IPS TFT LCD Display ST7789
Discription¶
This is a 1.3 inch display screen with a resolution of 240 (RGB) x240. It is an IPS full view LCD display panel so the color looks great in any direction. The drive IC is ST7789, and the universal 7-pin SPI interface is used.
The bottom has an SD card slot, which makes it easy to load full-color bitmaps from the MicroSD card in FAT16/FAT32 format.
Support the main control MCU such as ESP32/ESP8266/Arduino/STM32.
- 1.3 inch TFT LCD Display
- Built-in microSD slot
- Operating Voltage: 3.3V
- Backlight: 2-Chip white LED, Vf=3.2V(If=20mA)
- Resolution: 240 (RGB) x240
- Interface: SPI serial
- Drive IC: ST7789
- Operating Temperature: -20℃~+70℃
- Storage Temperature: -30℃~+80℃
- Dimension: 35.8mm x 35.8mm x 5.3mm
- Weight: 7.6g
Pin Discription¶
Hardware Connection¶
Crowduino Uno | 1.3 inch IPS TFT LCD Display |
[[File:|300px] | |
Get one now | [Get one now] |
STEP2 Connect wires according to the following wiring diagram
Software¶
STEP1 Download Adafruit-ST7735-Library and Adafruit-GFX-Library
STEP3 Install Library: Unzip the files and copy them to the Libraries directory under the Arduino installation directory
Note: Please change "-" in the folder name to "_", and delete"_ master"
STEP4 Open Arduino IDE, click "File"-->"Example"-->"Adafruit ST7735 and ST7789 Library"-->"graphicstest_st7789" to load the code
STEP5 Click the to upload the code to the Crowduino board
STEP6 The graphs will show on display
FAQS¶
