Crowbits-LED Bar
The LED light bar is a digital output module. Through the light bar, you can display the battery power, voltage value, water depth, sound size, and any other scene that needs to represent the gradient value.
- Detect various signals
- Interface Type:GPIO
- Operating Voltage: 3.3V DC
- Dimensions: 31.5(L)*24.5(W)*13(H)mm
Application Ideas¶
- Display test information
The following sketch demonstrates a simple application of digital display.
1.You need to prepare a Crowbits motherboard, such as Crowbits-UNO board.
2.Connect the module to the D2 and D3 interface on the Crowbits-UNO board, as shown in the figure:
3.Download the library Crowbits-LED Bar library. Unzip and put it in the libraries file, for example: C:\Program Files (x86)\Arduino\libraries.
4.Upload the following code to the Crowbits-UNO board.
  Crowtai LED Bar - Level Example
  This example will show you how to use setLevel() function of this library.
  The setLevel() function illuminates the given number of LEDs from either side.
  Syntax setLevel(level)
  0  = all LEDs off
  5  = 5 LEDs on
  10 = all LEDs on
#include <Grove_LED_Bar.h>
Grove_LED_Bar bar(2, 3, 0);  // Clock pin, Data pin, Orientation
  // nothing to initialize
  bar.begin();
  // Walk through the levels
  for (int i = 0; i <= 10; i++)
    bar.setLevel(i);
    delay(1000);
5. After the code is uploaded successfully, you will see the light bar change.
