Crowbits-Touch Sensor
The touch sensor is a digital input module, it’s a capacitive touch sensor. The touch sensor only has to be touched by an object to operate, it can be used as a touch switch.
- Low power consumption
- Digital input module
- Operating Voltage: 3.3V DC
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. When the sensor detects a hand touch, the LED behind it will light up.
