ENC28J60 Ethernet Module
The ENC28J60 Ethernet Module utilizes the new Microchip ENC28J60 Stand-Alone Ethernet Controller IC featuring a host of features to handle most of the network protocol requirements. The board connects directly to most microcontrollers with a standard SPI interface with a transfer speed of up to 20MHz.
Model:SIN16080E
- ENC28J60 Ethernet chips, SOP28 package
- SPI Interface
- 2X5 connector, can be easily mounted with the MCU
- Power indicator
- Single Supply: +3.3 V
- PCB size: 55x36 mm
1.Hardware Installation
2.Download the library File:ENC28J60 Library
3.Unzip it into the libraries file of Arduino IDE by the path: ..\arduino-1.0\libraries.
4.Open Arduino IDE Files -> Examples -> ENC_28J60 -> Helloworld.
The IP address in the example code need to be changed for the address assigned to ENC28J60 module.
// A simple web server that always just says "Hello World"
#include "etherShield.h"
#include "ETHER_28J60.h"
static uint8_t mac[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24}; // this just needs to be unique for your network,
// so unless you have more than one of these boards
// connected, you should be fine with this value.
static uint8_t ip[4] = {192, 168, 1, 15}; // the IP address for your board. Check your home hub
// to find an IP address not in use and pick that
// this or 10.0.0.15 are likely formats for an address
// that will work.
static uint16_t port = 80; // Use port 80 - the standard for HTTP
ETHER_28J60 ethernet;
ethernet.setup(mac, ip, port);
if (ethernet.serviceRequest())
ethernet.print("<H1>Hello World</H1>");
ethernet.respond();
delay(100);
5.Upload the code,then enter your Ethernet shield IP address into the URL bar.
