Crowtail- OLED
Crowtail- OLED is constructed from 128 x 64 dot matrix OLED module. The display offers high brightness, self-emission, high contrast ratio, slim/thin outline, wide viewing angle, wide temperature range and low power consumption.
Model: CT0025OD
- Connection Mode:I(IIC)
- Voltage: 5V
- Display Color:Bule/Black
- Resolution:128x64
- Interface:I2C
- Wide range of operating temperature: : -20°C~70°C
- Dimensions(mm):40.0(L)x20.0(W)x11.5(H)
1.Hardware connection
Connect the Crowtail- RGB-LED to I port.
3.Download the library OLED library;Unzip it into the libraries file of Arduino IDE by the path: ..\arduino-1.0.1\libraries.
4.Open the code directly by the path:File -> Example ->U8glib->Ele_0_96_12864.
#include "U8glib.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);
void drawColorBox(void)
u8g_uint_t w,h;
u8g_uint_t r, g, b;
w = u8g.getWidth()/32;
h = u8g.getHeight()/8;
for( b = 0; b < 4; b++ )
for( g = 0; g < 8; g++ )
for( r = 0; r < 8; r++ )
u8g.setColorIndex((r<<5) | (g<<2) | b );
u8g.drawBox(g*w + b*w*8, r*h, w, h);
void drawLogo(uint8_t d)
u8g.setFont(u8g_font_gdr25r);
u8g.drawStr(8+d, 30+d, "E");
u8g.drawStr(30+d,30+d,"l");
u8g.drawStr(40+d,30+d,"e");
u8g.drawStr(55+d,30+d,"c");
u8g.drawStr(70+d,30+d,"r");
u8g.drawStr(85+d,30+d,"o");
u8g.drawStr(100+d,30+d,"w");
void drawURL(void)
u8g.setFont(u8g_font_4x6);
u8g.drawStr(35,54,"www.elecrow.com");
void draw(void) {
if ( u8g.getMode() == U8G_MODE_R3G3B2 ) {
drawColorBox();
u8g.setColorIndex(1);
if ( U8G_MODE_GET_BITS_PER_PIXEL(u8g.getMode()) > 1 ) {
drawLogo(2);
u8g.setColorIndex(2);
drawLogo(1);
u8g.setColorIndex(3);
drawLogo(0);
drawURL();
void setup(void) {
void loop(void) {
// picture loop
u8g.firstPage();
do {
draw();
} while( u8g.nextPage() );
// rebuild the picture after some delay
delay(200);
5.Upload the Code,you shoule see the display of OLED.
