Mini PC Case With 1.3” OLED Screen For Raspberry Pi 5/Jetson Orin Nano¶
Model SEJ00007D
Pin Description:¶
| Module Signal Name | Net | Equipment |
| 1 | D2/I2C1_SDA D3/I2C1_SCL | IIC BUS: 3.3V BUS Barometer(ADD:0x77) Accelerometer&Gyro(ADD:0x68) Temperature & Humidity(ADD:0x38) LIGHT Sensor(ADD:0x5C) 5V BUS LCD (ADD:0x27) Digital display (ADD:0x70) I/O Expander (TCA9534APWR IO Expansion chip)(ADD:0x3C) STCG1K08A(Microcontroller) RP2040(Microcontroller) J21 and J22 (Reserved for user IIC interface) |
| 2 | D4 | Tilt sensor |
| 3 | D14/UART1_TXD | J23 (Reserve for user access via UART interface) |
| 4 | D15/UART1_RXD | J23 (Reserve for user access via UART interface) |
| 5 | D17/UART1_RTS | Touch Sensor |
| 6 | D27/SPI1_SCK | Vibration sensor |
| 7 | D23/SPI1_CS1 | PIR-Motion sensor |
| 8 | D25/SPI1_MISO | Photo Electric Counter |
| 9 | D10/SPI0_MOSI | SPI BUS: NFC Module(RC522 ) |
| 10 | D9/SPI0_MISO | SPI BUS: NFC Module(RC522 ) |
| 11 | D11/SPI0_SCK | SPI BUS: NFC Module(RC522 ) |
| 12 | D8/SPI0_CS0 | RC522 (NFC Chip Chip Select) |
| 13 | D6 | HALL SENSOR |
| 14 | D16/UART1_CTS | Ultrasonic Sensor TRIG |
| 15 | D26/SPI1_MOSI | Ultrasonic Sensor CTS |
| 16 | D20/I2S0_SDIN | IR Remote Sensor |
| 17 | D18/I2S0_SCLK | LED(Red LED indicator) |
| 18 | D13/PWM | J5(Reserve I/O ports for user use) |
| 19 | D12/PWM | J6(Reserve I/O ports for user use) |
| Expansion Interface Chip | chip pin | NET | Equipment |
| STCG1K28A(Microcontroller) | Pin1:P1.0 | ADC_CH0 | Joystick X-axis |
| Pin2:P1.1 | ADC_CH1 | Joystick Y-axis | |
| Pin3:P1.2 | ADC_CH2 | Linear Potentiometer | |
| Pin4:P1.3 | ADC_CH3 | GAS-MQ2 | |
| Pin5:P1.4 | ADC_CH4 | Custom_key | |
| Pin6:P1.5 | ADC_CH5 | NTC (Thermistor) | |
| Pin30:P0.1 | RELAY | Relay | |
| Pin31:P0.2 | BUZZER | Buzzer Control | |
| Pin13:RXD | STC8_RXD | Program Download | |
| Pin14:TXD | STC8_TXD | Program Download | |
| Pin7:SCL | D3/I2C1_SCL | IIC BUS | |
| Pin8:SDA | D2/I2C1_SDA | ||
| TCA9534APWR IO Expansion chip | Pin4:P0 | STEP1 | Stepper Motor Driver |
| Pin5:P1 | STEP2 | ||
| Pin6:P2 | STEP3 | ||
| Pin7:P3 | STEP4 | ||
| Pin12:P7 | ENCODER_B | Encode | |
| Pin11:P6 | ENCODER_A | ||
| Pin11:P5 | ENCODER_SW | ||
| RP2040 | Pin47 | USB_D+ | USB download port |
| Pin46 | USB_D- | ||
| Pin39:P27 | RP2040_IO27_RGB_POWER_EN | 8*8 RGB Power Control | |
| Pin8:P6 | RP2040_IO6_RGB | 8*8 RGB Signal | |
| Pin16:P13 | RP2040_IO13_SERVO_1 | Gimbal Servo Interface | |
| Pin17:P14 | RP2040_IO13_SERVO_2 | Gimbal Servo Interface | |
| Pin21:P32 | D2/I2C1_SDA | IIC BUS | |
| Pin20:P31 | D3/I2C1_SCL |
Jetson Nano Module Interface Pin Description
| Feature | Module Signal Name | Pin | Pin | Module Signal Name | Feature | |
| VCC3V3 | 1 | 2 | VCC5V | |||
| D2/I2C1_SDA | 3 | 4 | VCC5V | |||
| D3/I2C1_SCL | 5 | 6 | GND | |||
| D4 | 7 | 8 | D14/UART1_TXD | |||
| GND | 9 | 10 | D15/UART1_RXD | |||
| D17/UART1_RTS | 11 | 12 | D18/I2S0_SCLK | |||
| D27/SPI1_SCK | 13 | 14 | GND | |||
| D22/LCD_TE* | 15 | 16 | D23/SPI1_CS1 | |||
| VCC3V3 | 17 | 18 | D24/SPI1_CS0 | |||
| D10/SPI0_MOSI | 19 | 20 | GND | |||
| D9/SPI0_MISO | 21 | 22 | D25/SPI1_MISO | |||
| D11/SPI0_SCK | 23 | 24 | D8/SPI0_CS0 | |||
| GND | 25 | 26 | D7/SPI0_CS1 | |||
| D0/ID_I2C_SDA | 27 | 28 | D1/ID_I2C_SCL | |||
| D5/CAM_AF_EN* | 29 | 30 | GND | |||
| D6 | 31 | 32 | D12/PWM | |||
| D13/PWM | 33 | 34 | GND | |||
| D19/I2S0_LRCK | 35 | 36 | D16/UART1_CTS | |||
| D26/SPI1_MOSI | 37 | 38 | D20/I2S0_SDIN | |||
| GND | 39 | 40 | D21/I2S0_SDOUT |
Hardware Overview¶
Sensor Courses¶
Camera Courses¶
User guide:¶
Solid-State Flashing and Boot Methodology and SD Card Flashing Guide:¶
Github:¶
AI-Starter-Kit-for-Jetson-Orin-Nano-with-Common-Board-design
Guide Video:¶
Unboxing & Setting Up the AI Starter Kit for Jetson Orin Nano | Beginner's Guide
Master Camera & AI Vision: Hands-On Starter Kit Course for Jetson Orin Nano
Openclaw Column¶
Jetson OpenClaw Install & Config Guide
How to buy¶
Please visit this page to purchase AI Starter Kit for Jetson Orin Nano.
Support¶
