Crowbits-Linear Potentiometer
The linear potentiometer is an analog input module, it changes the resistance of the whole circuit to control your circuit.
- Analog input module
 - Linear resistance taper
- Operating Voltage: 3.3V DC
 - The range of resistance of the potentiometer: 0~5KΩ
 - 18mm long slide length
1. You also need to prepare a power module, such as Crowbits-Power Supply, and an output module, such as Crowbits-LED.
3. Then, turn on the power. Sliding the rheostat, you can see that the LED will have a progressive effect of darkening or brightening.
