CrowPanel ESP32 5.0-inch with ESP-IDF¶
IDF Version V5.5.4 Ivgl: 8.3.11
Overview¶
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to upload the code with ESP-IDF.
Hardware Preparation¶
| CrowPanel ESP32 5.0'' HMI | Crowtail-DHT20 | Crowtail-LED | Dupont-wire |
Open the SquareLine Studio and create a project.
Set the name of the project, set the screen resolution to 800*480, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
Images only support webp format. The pixels of the image need to be smaller than the pixel size of the screen used in your project. The size of each image should not exceed 100k, preferably within 30k, to provide a smooth display effect.
Add background.
You can set the font colour and other attributes in STYLE SETTING→STYLE(MAIN).
Add events to buttons.
Select "clicked" as the trigger condition, select a trigger event in "Action". It will be modified in the generated program to achieve the LED control function.
Export UI files.
Then click "APPLY CHANGES".
Build the Project with ESP-IDF¶
Get Started with ESP-IDF¶
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
You can click
to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Library introduction¶
#include <lvgl.h>
#include <DHT20.h>
#include <SPI.h>
#include <Arduino_GFX_Library.h>
#include <Arduino.h>
#include "ui.h"
#include <lvgl.h>: Library for UI interaction#include <DHT20.h>: The library of temperature and humidity sensors#include <SPI.h>: Screen driven library.#include <Arduino.h>: This is the core Arduino header file. It must be included when using the Arduino framework.#include <Arduino_GFX_Library.h>: This library handles the initialization and configuration of the display, including resolution, driver settings, and interface pins.#include "ui.h": is a custom header file that contain UI-related functions or definitions.
Code Explanation¶
Basic Definition
- Set the screen cache
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 0 /* PCLK */,
45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */,
5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */,
8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */,
0 /* hsync_polarity */, 8 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 43 /* hsync_back_porch */,
0 /* vsync_polarity */, 8 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 12 /* vsync_back_porch */,
1 /* pclk_active_neg */, 9000000 /* prefer_speed */, false /* useBigEndian */,
0 /* de_idle_high */, 0 /* pclk_idle_high */, 480 /* bounce_buffer_size_px */
Arduino_RGB_Display *lcd = new Arduino_RGB_Display(
800 /* width */, 480 /* height */, bus, 0 /* rotation */, false /* auto_flush */);
- Automatically refresh temperature and humidity data in real time.
void update_sensor_values() {
int temperature = dht20.getTemperature();
int humidity = dht20.getHumidity();
if (ui_Label1) lv_label_set_text_fmt(ui_Label1, "%d", temperature);
if (ui_Label2) lv_label_set_text_fmt(ui_Label2, "%d", humidity);
Serial.print("Temp: ");
Serial.print(temperature);
Serial.println(" °C");
Serial.print("Humi: ");
Serial.print(humidity);
Serial.println(" %");
- Touch reading function
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (touch_has_signal())
if (touch_touched())
data->point.x = touch_last_x;
data->point.y = touch_last_y;
Serial.printf("[LVGL] x=%d y=%d\n", touch_last_x, touch_last_y);
else if (touch_released())
else
delay(15);
- Refresh function
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
uint32_t w = (area->x2 - area->x1 + 1);
uint32_t h = (area->y2 - area->y1 + 1);
#if (LV_COLOR_16_SWAP != 0)
lcd->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
lcd->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#endif
lv_disp_flush_ready(disp);
Setup Part
Serial.begin(115200);
delay(100);
Serial.println("setup() start");
dht20.begin();
// PCA9557 LCD power/reset control (matching Arduino version logic)
Wire.begin(19, 20);
Out.reset();
Out.setMode(IO_OUTPUT); // Set all pins as output first
Out.setState(0, IO_LOW);
Out.setState(1, IO_LOW);
delay(20);
Out.setState(0, IO_HIGH);
delay(100);
Out.setMode(1, IO_INPUT); // IO1 as input
// Control pin 38 (matching Arduino version)
pinMode(38, OUTPUT);
digitalWrite(38, LOW);
lv_init();
Serial.println("Calling lcd->begin()...");
bool ok = lcd->begin();
Serial.printf("lcd->begin() returned: %d\r\n", ok);
if (!ok) {
Serial.println("lcd->begin() failed, halt");
while (1) {
delay(1000);
// Test: fill screen with black (matching Arduino version)
lcd->fillScreen(0x0000);
delay(100);
touch_init();
delay(50);
//pinMode(38, OUTPUT);
//digitalWrite(38, LOW);
screenWidth = lcd->width();
screenHeight = lcd->height();
// Use 1/10 of screen as draw buffer (recommended for LVGL 8.x)
const size_t draw_buf_pixels = screenWidth * screenHeight / 10;
lvgl_draw_buf = (lv_color_t *)heap_caps_malloc(draw_buf_pixels * sizeof(lv_color_t),
MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT);
if (!lvgl_draw_buf) {
Serial.println("draw buffer alloc failed");
while (1) {
delay(1000);
lv_disp_draw_buf_init(&draw_buf, lvgl_draw_buf, NULL, draw_buf_pixels);
lv_disp_drv_init(&disp_drv);
ui_init();
// Turn on backlight (matching Arduino version timing)
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
Serial.println("Setup done");
Main Program Part
static uint32_t last_tick_ms = millis();
uint32_t now = millis();
lv_tick_inc(now - last_tick_ms);
last_tick_ms = now;
lv_timer_handler();
delay(5);
// Handle LED state changes from UI button events
if (led != last_led_state) {
last_led_state = led;
// TODO: Change LED_PIN to match your actual LED connection
const int LED_PIN = 38;
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, led ? HIGH : LOW);
Serial.printf("LED state changed: %d\n", led);
static unsigned long last_update = 0;
if (millis() - last_update > 2000) {
update_sensor_values();
last_update = millis();
Setup board¶
Download the program¶
Connect the ESP32 Display to the PC and compile the program.
After confirming the serial port, select the UART mode.
After the program is successfully downloaded, connect the DHT20 sensor to the IIC port and the LED to GPIO_D (IO25), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
