Lesson5 SD card stores images and displays them locally
Welcome to the application tutorial of Lesson 5. The effect to be achieved in this lesson is to store the images that need to be displayed on the SD card and display them on the CrowPanel ESP32 Advance HMI.
1 Select the photos you want to display on the browser and save them on the desktop (the save path can be customized)
2 Modify the resolution of the image based on the size of the product you are using.
2
Here, for large-sized products, I will take the 5.0-inch product as an example to introduce how to modify the resolution of images.
The resolution of the 5.0-inch product is 320x240.
(Note: The image resolution of 7.0-inch, 5.0-inch, and 5.0-inch products is consistent, and the code and image can be used interchangeably.)
3
4
5
Adjust the pixel to 5.0-inch screen resolution: 320x240
6
Click confirm
7
8
9
10
11
12
3 Insert the SD card containing this saved image into your CrowPanel ESP32 Advance HMI
13
(5.0 inch, 2.8 inch, 5.0 inch products can be directly inserted for use)
14
(After inserting the SD card, turn the function switch to 1 0 mode (TF Card mode) for 5.0-inch, 5.0-inch and 7.0-inch.)
4 Open the code we provide
Code download link:https://github.com/Elecrow-RD/CrowPanel-Advance-5-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/tree/master/example/ESP_IDF
Download it to the Desktop and Open it with VS Code
15
5 Configure the runtime environment and burn code
After Connecting the Device, Select the Serial Port
16
16
Set the Main Control Chip to: ESP32-S3
18
18
18
Click "Build Project". Once the compilation is complete, click "Flash Device".
18
18
6 Phenomenon display
22
23
24
25
26
Version 1.1 Key Points.
Version 1.1 updated the control of backlight on the basis of the original, the backlight of version 1.1 is controlled by STC8H1K28 microcontroller, and the backlight is lit in the program by sending the value to this microcontroller address (0x30). The values are 0x05, 0x06, 0x07, 0x08, 0x09 and 0x10, where 0x05 switches off the backlight and 0x10 is the maximum brightness.
When the main program is running, you need to query the i2c address all the time to prevent the microcontroller from not starting to adjust the bright screen.
The function code for data transfer is as follows, as well as the code in the main program for how to send the value to light the backlight.
