CrowPanel ESP32 Terminal RGB with ESP-IDF¶
Overview¶
The example tutorial is an environmental monitoring project, demonstrate how to create a UI and use a Humidity&Temperature sensor to obtain the environment temperature and humidity and display it on the screen; and how to control the LED on and off by the buttons on the screen.
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to build a project on ESP-IDF.
Hardware Preparation¶
| ESP32 Terminal RGB | Crowtail-AM2302 | Crowtail-LED |
Open the SquareLine Studio and create a project. Select "Elecrow"->"DLC35010R - ESP32 Terminal...-Arduino-IDE".
Set the name of the project, set the screen resolution to 480*320, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
to download the custom images used in this tutorial. Note:
Add background.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
You can click
to download the export UI files we provided.The UI file export is completed, and the button event function is also modified. Next we're going to learn about how to create a ESP-IDF project.
Create ESP-IDF Project¶
Get Started with ESP-IDF¶
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
You can click
to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Create New Project¶
Create a new project according to the "Get Started with ESP-IDF". Choose "ESP320S3 chip(via ESP-PROG)" as ESP-IDF Target.
Add Libraries¶
Create a new folder and name the folder 'components'. Add the libraries we provided to this folder.
Please click
to download the libraries we provided.
Configuring the UI File¶
Modify CMakeLists.txt
Change from:
to:
idf_component_register(SRCS "ui.c"
"ui_comp.c"
"ui_Screen1.c"
"ui_comp_button2.c"
"ui_comp_hook.c"
"ui_helpers.c"
"ui_img_background_png.c"
"ui_img_on_png.c"
"ui_img_off_png.c"
INCLUDE_DIRS "."
PRIV_REQUIRES lvgl-3)
Modify the button event code.
First, define a extern int led; in the ui.h file to store the status of the LED. The value of this variable is judged to control the on and off of the LED.
Setup main file¶
The CMakeList.txt file contains the Settings for the library. All required libraries should be included by directory address.
The main program is written in the .cpp file
#include <Arduino.h>
#include <lvgl.h>
#include <LovyanGFX.hpp>
#include "FT6236.h"
#include "ui.h"
#include <stdio.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/gpio.h"
#include "rom/ets_sys.h"
#include "esp_rom_gpio.h"
#define DHT_22 GPIO_NUM_40
#define uchar unsigned char
#define uint8 unsigned char
#define uint16 unsigned short
//Definition of temperature and humidity
uchar uchartemp;//COM function call, data transfer
float Humi,Temp;
//uchar ucharT_data_H,ucharT_data_L,ucharRH_data_H,ucharRH_data_L,ucharcheckdata;//验证过后传递数据
uchar ucharT_data_H_temp,ucharT_data_L_temp,ucharRH_data_H_temp,ucharRH_data_L_temp,ucharcheckdata_temp;
uchar ucharcomdata;//Stores data obtained by com
const int i2c_touch_addr = TOUCH_I2C_ADD;
#define LCD_BL 46
#define SDA_FT6236 38
#define SCL_FT6236 39
int led;
static void InputInitial()
esp_rom_gpio_pad_select_gpio(DHT_22);
gpio_set_direction(DHT_22, GPIO_MODE_INPUT);
static void OutputHigh(void)//Output 1
gpio_set_direction(DHT_22, GPIO_MODE_OUTPUT);
gpio_set_level(DHT_22, 1);
static void OutputLow(void)//Output 1
gpio_set_level(DHT_22, 0);
static uint8 getData()//Read Status
return gpio_get_level(DHT_22);
//Read a byte of data
static void COM()
uchar i;
for (i=0;i<8;i++)
while(!getData())
uchartemp=0;
ets_delay_us(35);//Delay 35us
if(getData()==1)
uchartemp=1;
ucharcomdata <<= 1;
ucharcomdata |= uchartemp;
while(getData());
void DHT22(void) //Temperature and humidity sensor start
OutputLow();
ets_delay_us(1000);
OutputHigh();
ets_delay_us(40);
InputInitial(); //Input
if(!getData())//Indicates that the sensor pulls the bus low
//Waiting for the bus to be pulled high by the sensor
while(!getData())
ets_delay_us(10);
while(getData())
ets_delay_us(10);
COM();//Read the first byte,
ucharRH_data_H_temp=ucharcomdata;
COM();//Read the second byte,
ucharRH_data_L_temp=ucharcomdata;
COM();//Read the 3rd byte,
ucharT_data_H_temp=ucharcomdata;
COM();//Read the 4th byte,
ucharT_data_L_temp=ucharcomdata;
COM();//Read the 5th byte,
ucharcheckdata_temp=ucharcomdata;
OutputHigh();
//Determine whether the checksum is consistent
uchartemp=(ucharT_data_H_temp+ucharT_data_L_temp+ucharRH_data_H_temp+ucharRH_data_L_temp);
if(uchartemp==ucharcheckdata_temp)
//Checksums are consistent,
/*ucharRH_data_H=ucharRH_data_H_temp;
ucharRH_data_L=ucharRH_data_L_temp;
ucharT_data_H=ucharT_data_H_temp;
ucharT_data_L=ucharT_data_L_temp;
ucharcheckdata=ucharcheckdata_temp;*/
//Storage temperature and humidity
Humi=ucharRH_data_H_temp;
Humi=((uint16)Humi<<8|ucharRH_data_L_temp)/10;
Temp=ucharT_data_H_temp;
Temp=((uint16)Temp<<8|ucharT_data_L_temp)/10;
else
Humi=100;
Temp=100;
else //If the read fails, return 0
Humi=0,
Temp=0;
Serial.println(123);
OutputHigh(); //Output
lgfx::Panel_ILI9488 _panel_instance;
lgfx::Bus_Parallel16 _bus_instance;
public:
LGFX(void)
cfg.port = 0;
cfg.freq_write = 80000000;
cfg.pin_wr = 18;
cfg.pin_rd = 48;
cfg.pin_rs = 45;
cfg.pin_d0 = 47;
cfg.pin_d1 = 21;
cfg.pin_d2 = 14;
cfg.pin_d3 = 13;
cfg.pin_d4 = 12;
cfg.pin_d5 = 11;
cfg.pin_d6 = 10;
cfg.pin_d7 = 9;
cfg.pin_d8 = 3;
cfg.pin_d9 = 8;
cfg.pin_d10 = 16;
cfg.pin_d11 = 15;
cfg.pin_d12 = 7;
cfg.pin_d13 = 6;
cfg.pin_d14 = 5;
cfg.pin_d15 = 4;
_bus_instance.config(cfg);
cfg.pin_cs = -1;
cfg.pin_rst = -1;
cfg.pin_busy = -1;
cfg.memory_width = 320;
cfg.memory_height = 480;
cfg.panel_width = 320;
cfg.panel_height = 480;
cfg.offset_x = 0;
cfg.offset_y = 0;
cfg.offset_rotation = 2;
cfg.dummy_read_pixel = 8;
cfg.dummy_read_bits = 1;
cfg.readable = true;
cfg.invert = false;
cfg.rgb_order = false;
cfg.dlen_16bit = true;
cfg.bus_shared = true;
_panel_instance.config(cfg);
setPanel(&_panel_instance);
LGFX tft;
/*Change to your screen resolution*/
static const uint16_t screenWidth = 480;
static const uint16_t screenHeight = 320;
static lv_color_t buf[screenWidth * screenHeight / 5];
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
uint32_t w = (area->x2 - area->x1 + 1);
uint32_t h = (area->y2 - area->y1 + 1);
tft.startWrite();
tft.setAddrWindow(area->x1, area->y1, w, h);
tft.writePixels((lgfx::rgb565_t *)&color_p->full, w * h);
tft.endWrite();
lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
int pos[2] = {0, 0};
ft6236_pos(pos);
if (pos[0] > 0 && pos[1] > 0)
// data->point.x = tft.width()-pos[1];
// data->point.y = pos[0];
data->point.x = tft.width() - pos[1];
Serial.printf("x-%d,y-%d\n", data->point.x, data->point.y);
else
void touch_init()
// I2C init
Wire.begin(SDA_FT6236, SCL_FT6236);
byte error, address;
Wire.beginTransmission(i2c_touch_addr);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
Serial.print(i2c_touch_addr, HEX);
Serial.println(" !");
else if (error == 4)
Serial.print("Unknown error at address 0x");
Serial.println(i2c_touch_addr, HEX);
extern "C" void app_main()
Serial.begin(115200); /* prepare for possible serial debug */
//IO口引脚
pinMode(19, OUTPUT);
digitalWrite(19, LOW);
tft.begin(); /* TFT init */
tft.setRotation(1); /* Landscape orientation, flipped */
tft.fillScreen(TFT_BLACK);
delay(500);
pinMode(LCD_BL, OUTPUT);
digitalWrite(LCD_BL, HIGH);
touch_init();
lv_init();
lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * screenHeight / 5);
/*Initialize the display*/
lv_disp_drv_init(&disp_drv);
/*Change the following line to your display resolution*/
/*Initialize the (dummy) input device driver*/
Serial.println("Setup done");
ui_init();
while (1)
DHT22();
Serial.println(Temp);
Serial.println(Humi);
printf("Temp=%.2f--Humi=%.2f%%RH \r\n", Temp,Humi);
char DHT_buffer[6];
int a = (int)Temp;
int b = (int)Humi;
if(a!=0 || b!=0){
if(led == 1)
digitalWrite(19, HIGH);
if(led == 0)
delay(100);
Upload the code¶
Board Setting¶
Confirm the path
SDK Configuration¶
Serial flash config:
ESP32SE-Specific→Cache config:
LVGL Configuration: Uncheck the "Uncheck this to use custom lv_conf.h"
Save the setting
Compile and upload the code¶
Click Compile and the compilation is successful.
Click the download button to download the program (confirm the serial port and select UART mode to download)
