CrowPanel ESP32 7.0-inch with PlatformIO¶
Overview¶
The example is an environmental monitoring project, using a DHT20 sensor to obtain the environment temperature and humidity and display it on the screen; and control the LED on and off by the buttons on the screen.
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to build a project on PlatformIO.
Hardware Preparation¶
| CrowPanel ESP32 7.0'' HMI | Crowtail-DHT20 | Crowtail-LED |
Note:
Set the name of the project, set the screen resolution to 800*480, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
Images only support webp format. The pixels of the image need to be smaller than the pixel size of the screen used in your project. The size of each image should not exceed 100k, preferably within 30k, to provide a smooth display effect.
Add background.
Find "Inspector"->"STYLE SETTING", click to expand "STYLE(MAIN)", then click the 2nd "Background"(in v1.3.4 is "Background image"). Check the "Bg Image" and select the background image.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
Modify the button event code.
First, define a ‘extern int led;' in the ui.h file to store the status of the LED. The value of this variable is judged to control the on and off of the LED.
The UI file export is completed, and the button event function is also modified. Next we're going to learn about how to create a PlatformIO project.
Create PlatformIO Project¶
Please click
to download the complete PlatformIO project — it works out of the box.
Now let's break down how this project was built step by step.
Get Started with PlatformIO¶
Please click the card below to enter the page to get started with PlatformIO.
Create a new project¶
Place the esp32-s3-devkitc-1-myboard.json to the directory in the following picture:
Please click
to download the esp32-s3-devkitc-1-myboard.json. -
Open Visual Studio Code, click the PlatformIO icon, click QUIK ACCESS 'Open', then click '+New Project'.
Add a project name "CrowPanel_ESP32_7.0". Select "Espressif ESP32-S3-DevKitC-1-N8 -ELECROW" for the board and Arduino for the framework.
Add the following code to the platformio.ini file
[platformio] src_dir = src boards_dir = . build_flags = -D LV_LVGL_H_INCLUDE_SIMPLE -I./include board_build.partitions = huge_app.csv platform_packages = framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32#2.0.3Please copy the huge_app.csv file from the materials we provide to the project root directory.
Write the main program in main.cpp.
#include <lvgl.h> #include <DHT20.h> #include <LovyanGFX.hpp> #include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp> #include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp> #include <SPI.h> #include "ui.h" class LGFX : public lgfx::LGFX_Device { public: lgfx::Bus_RGB _bus_instance; lgfx::Panel_RGB _panel_instance; LGFX(void) { { auto cfg = _bus_instance.config(); cfg.panel = &_panel_instance; cfg.pin_d0 = GPIO_NUM_15; // B0 cfg.pin_d1 = GPIO_NUM_7; // B1 cfg.pin_d2 = GPIO_NUM_6; // B2 cfg.pin_d3 = GPIO_NUM_5; // B3 cfg.pin_d4 = GPIO_NUM_4; // B4 cfg.pin_d5 = GPIO_NUM_9; // G0 cfg.pin_d6 = GPIO_NUM_46; // G1 cfg.pin_d7 = GPIO_NUM_3; // G2 cfg.pin_d8 = GPIO_NUM_8; // G3 cfg.pin_d9 = GPIO_NUM_16; // G4 cfg.pin_d10 = GPIO_NUM_1; // G5 cfg.pin_d11 = GPIO_NUM_14; // R0 cfg.pin_d12 = GPIO_NUM_21; // R1 cfg.pin_d13 = GPIO_NUM_47; // R2 cfg.pin_d14 = GPIO_NUM_48; // R3 cfg.pin_d15 = GPIO_NUM_45; // R4 cfg.pin_henable = GPIO_NUM_41; cfg.pin_vsync = GPIO_NUM_40; cfg.pin_hsync = GPIO_NUM_39; cfg.pin_pclk = GPIO_NUM_0; cfg.freq_write = 15000000; cfg.hsync_polarity = 0; cfg.hsync_front_porch = 40; cfg.hsync_pulse_width = 48; cfg.hsync_back_porch = 40; cfg.vsync_polarity = 0; cfg.vsync_front_porch = 1; cfg.vsync_pulse_width = 31; cfg.vsync_back_porch = 13; cfg.pclk_active_neg = 1; cfg.de_idle_high = 0; cfg.pclk_idle_high = 0; _bus_instance.config(cfg); } { auto cfg = _panel_instance.config(); cfg.memory_width = 800; cfg.memory_height = 480; cfg.panel_width = 800; cfg.panel_height = 480; cfg.offset_x = 0; cfg.offset_y = 0; _panel_instance.config(cfg); } _panel_instance.setBus(&_bus_instance); setPanel(&_panel_instance); } }; LGFX lcd; //UI #define TFT_BL 2 int led; DHT20 dht20; SPIClass& spi = SPI; #include "touch.h" /* Change to your screen resolution */ static uint32_t screenWidth; static uint32_t screenHeight; static lv_disp_draw_buf_t draw_buf; //static lv_color_t *disp_draw_buf; static lv_color_t disp_draw_buf[800 * 480 / 15]; static lv_disp_drv_t disp_drv; /* Display flushing */ void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) { uint32_t w = (area->x2 - area->x1 + 1); uint32_t h = (area->y2 - area->y1 + 1); //lcd.fillScreen(TFT_WHITE); #if (LV_COLOR_16_SWAP != 0) lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full); #else lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full);// #endif lv_disp_flush_ready(disp); } void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data) { if (touch_has_signal()) { if (touch_touched()) { data->state = LV_INDEV_STATE_PR; /*Set the coordinates*/ data->point.x = touch_last_x; data->point.y = touch_last_y; Serial.print( "Data x " ); Serial.println( data->point.x ); Serial.print( "Data y " ); Serial.println( data->point.y ); } else if (touch_released()) { data->state = LV_INDEV_STATE_REL; } } else { data->state = LV_INDEV_STATE_REL; } delay(15); } //PCA9557 Out; void setup() { Serial.begin(9600); //IO口引脚 pinMode(38, OUTPUT); digitalWrite(38, LOW); Wire.begin(19, 20); dht20.begin(); // Init Display lcd.begin(); lcd.fillScreen(TFT_BLACK); lcd.setTextSize(2); delay(200); lv_init(); // Init touch device touch_init(); screenWidth = lcd.width(); screenHeight = lcd.height(); lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 15); //4 /* Initialize the display */ lv_disp_drv_init(&disp_drv); /* Change the following line to your display resolution */ disp_drv.hor_res = screenWidth; disp_drv.ver_res = screenHeight; disp_drv.flush_cb = my_disp_flush; disp_drv.draw_buf = &draw_buf; lv_disp_drv_register(&disp_drv); /* Initialize the (dummy) input device driver */ static lv_indev_drv_t indev_drv; lv_indev_drv_init(&indev_drv); indev_drv.type = LV_INDEV_TYPE_POINTER; indev_drv.read_cb = my_touchpad_read; lv_indev_drv_register(&indev_drv); #ifdef TFT_BL //digitalWrite(TFT_BL, HIGH); ledcSetup(1, 300, 8); ledcAttachPin(TFT_BL, 1); ledcWrite(1, 255); /* Screen brightness can be modified by adjusting this parameter. (0-255) */ #endif #ifdef TFT_BL pinMode(TFT_BL, OUTPUT); digitalWrite(TFT_BL, LOW); delay(500); digitalWrite(TFT_BL, HIGH); #endif ui_init(); lv_timer_handler(); } void loop() { char DHT_buffer[6]; int a = (int)dht20.getTemperature(); int b = (int)dht20.getHumidity(); snprintf(DHT_buffer, sizeof(DHT_buffer), "%d", a); lv_label_set_text(ui_Label1, DHT_buffer); snprintf(DHT_buffer, sizeof(DHT_buffer), "%d", b); lv_label_set_text(ui_Label2, DHT_buffer); if(led == 1) digitalWrite(38, HIGH); if(led == 0) digitalWrite(38, LOW); lv_timer_handler(); /* let the GUI do its work */ delay( 10 ); }
Add Libraries¶
Click the PlatformIO icon, click QUIK ACCESS 'Open', then click 'Libraries'.
Search for LVGL, and add it to the project.
After adding, right click on lvgl and select "Open in Integrated Terminal"
Copy the "demos" and "examples" folders to "src" folder
Place the lv_conf.h we provide to the path: .pio\libdeps\esp32-s3-devkitc-1-myboard in the project folder.
Add LovyanGFX library
Add GT911
Add Adafruit_Busio
We can see that the library has been added successfully!
This project uses a temperature and humidity sensor(DHT20). We need to add the DHT20 library. Right-click the "libdeps\esp32-s3-devkitc-1-myb...", click "Reveal in File Explorer", and select the DHT20 library we provided.
Add the UI file into PlatformIO Project¶
We need to add the UI file (generated from SquareLine Studio) to the PlatformIO project.
The .c file in the UI file should be placed in the /scr folder of the project file, and the .h files should be placed in the /include folder.
Note: The touch.h referenced here should be replaced with the touch.h file we provide.
Upload the Code¶
Compile the program.
Select the serial port and upload the code.
Here we select Auto. The software will automatically select the corresponding serial port for program download. If the automatically selected serial port is incorrect, you can manually select the correct serial port.
Click the upload button to up the program to the board.
The program will run on the board!
Code Explanation¶
Library introduction
- LVGL: UI library
- SPI.h: Screen driven library
- lv_demos: lvgl built-in demos library
- DHT20.h: temperature and humidity sensor library
- LovyanGFX.hpp: LovyanGFX library is a library for drawing graphics on embedded systems, providing rich graphics functions and APIs
- lgfx/v1/platforms/esp32s3/Panel_RGB.hpp: lgfx/v1/platforms/esp32s3/Bus_RGB.hpp:
- These two libraries are part of the LovyanGFX library, specifically for driving RGB color panels on ESP32-S3 microcontrollers. Panel_RGB.hpp provides functions for communicating with RGB panels, while Bus_RGB.hpp provides functions for communicating with RGB buses, which are usually used to control devices such as LCD screens.
- ui.h: files generated by squareline studio
include
¶ #include
#include #include #include #include #include "ui.h" ``` -
Definition
LGFX class, which is a subclass of lgfx::LGFX_Device. The main function is to configure and initialize an RGB color panel, and then connect it to the RGB bus on the ESP32-S3 microcontroller to display graphics on the panel.
class LGFX : public lgfx::LGFX_Device { public: lgfx::Bus_RGB _bus_instance; lgfx::Panel_RGB _panel_instance; LGFX(void) { { auto cfg = _bus_instance.config(); cfg.panel = &_panel_instance; cfg.pin_d0 = GPIO_NUM_15; // B0 cfg.pin_d1 = GPIO_NUM_7; // B1 cfg.pin_d2 = GPIO_NUM_6; // B2 cfg.pin_d3 = GPIO_NUM_5; // B3 cfg.pin_d4 = GPIO_NUM_4; // B4 cfg.pin_d5 = GPIO_NUM_9; // G0 cfg.pin_d6 = GPIO_NUM_46; // G1 cfg.pin_d7 = GPIO_NUM_3; // G2 cfg.pin_d8 = GPIO_NUM_8; // G3 cfg.pin_d9 = GPIO_NUM_16; // G4 cfg.pin_d10 = GPIO_NUM_1; // G5 cfg.pin_d11 = GPIO_NUM_14; // R0 cfg.pin_d12 = GPIO_NUM_21; // R1 cfg.pin_d13 = GPIO_NUM_47; // R2 cfg.pin_d14 = GPIO_NUM_48; // R3 cfg.pin_d15 = GPIO_NUM_45; // R4 cfg.pin_henable = GPIO_NUM_41; cfg.pin_vsync = GPIO_NUM_40; cfg.pin_hsync = GPIO_NUM_39; cfg.pin_pclk = GPIO_NUM_0; cfg.freq_write = 15000000; cfg.hsync_polarity = 0; cfg.hsync_front_porch = 40; cfg.hsync_pulse_width = 48; cfg.hsync_back_porch = 40; cfg.vsync_polarity = 0; cfg.vsync_front_porch = 1; cfg.vsync_pulse_width = 31; cfg.vsync_back_porch = 13; cfg.pclk_active_neg = 1; cfg.de_idle_high = 0; cfg.pclk_idle_high = 0; _bus_instance.config(cfg); } { auto cfg = _panel_instance.config(); cfg.memory_width = 800; cfg.memory_height = 480; cfg.panel_width = 800; cfg.panel_height = 480; cfg.offset_x = 0; cfg.offset_y = 0; _panel_instance.config(cfg); } _panel_instance.setBus(&_bus_instance); setPanel(&_panel_instance); } }; LGFX lcd;///* (1) The LGFX class inherits from lgfx::LGFX_Device, which means it will inherit the member variables and methods defined in LGFX_Device. (2) In the constructor of the LGFX class, we first create an instance of _bus_instance for lgfx::Bus_RGB and an instance of _panel_instance for lgfx::Panel_RGB. (3) Next, initialize the RGB bus and RGB panel by configuring the parameters of these two instances. In this code, data pins for each color are set, as well as some parameters related to synchronization signals and clocks, to ensure the correct transmission and display of data. (4) The configuration of _bus_instance and _panel_instance is based on their respective configuration objects, which are lgfx::Bus_RGB::config_t and lgfx::Panel_RGB::config_t. (5) Finally, set the bus used by the panel by calling _panel_instance.setBus(&_bus_instance), and then call setPanel(&_panel_instance) to set the panel as the panel of the current device. (6) Finally, a global LGFX object lcd was created for graphical drawing operations using this configured panel elsewhere. */ -
Define backlight pins, led variables, and screen resolution parameters. And include touch driver.
Define a buffer variable to initialize the display driver of LVGL and prepare a buffer to store pixel data that will be rendered to the screen. The size of this buffer should be around 1/10 of the product of screen pixel values, which can balance the main control performance and the smoothness of screen display. Taking 10 as an example, the display will be smoother.
Initialize temperature and humidity sensors and an instance of SPI library
Function
Screen refresh function, this code is for the refresh function driven by the display in the LittlevGL (LVGL) graphics library. LVGL is an open-source graphics library for embedded systems, used to create graphical user interfaces (GUIs). This function my_disp_flush is a user-defined callback function used to refresh the content of the graphical interface onto the display device.
/* Display flushing */ void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) { uint32_t w = (area->x2 - area->x1 + 1); uint32_t h = (area->y2 - area->y1 + 1); //lcd.fillScreen(TFT_WHITE); #if (LV_COLOR_16_SWAP != 0) lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full); #else lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full);// #endif lv_disp_flush_ready(disp); } -
A simple touch input device reading function, which is used to convert touch events into the input device data format required by the LVGL library, and output the coordinate information of touch points through serial communication.
Set Up Part
void setup() { Serial.begin( 115200 ); /*Initializing the Serial Port*/ //IO Port Pins pinMode(38, OUTPUT); digitalWrite(38, LOW); //initialization of DHT20 pins(I2C) Wire.begin(19, 20); dht20.begin(); lv_init(); // LVGL initialization lcd.begin(); lcd.fillScreen(TFT_BLACK); delay(300); lv_init() delay(100); touch_init(); // Touch initialization /*Obtain the width and height of the screen, and initialize the drawing buffer.*/ screenWidth = lcd.width(); screenHeight = lcd.height();
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 15); // lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, 480 * 272 / 10); /* Initialize the display / lv_disp_drv_init(&disp_drv); / Change the following line to your display resolution */ disp_drv.hor_res = screenWidth; disp_drv.ver_res = screenHeight; disp_drv.flush_cb = my_disp_flush; disp_drv.draw_buf = &draw_buf; lv_disp_drv_register(&disp_drv);
/*Initialize the (virtual) input device driver*/
static lv_indev_drv_t indev_drv;//Define the input device driver structure
lv_indev_drv_init( &indev_drv );//Initialize the input device driver
indev_drv.type = LV_INDEV_TYPE_POINTER;//Setting the input device type
indev_drv.read_cb = my_touchpad_read;//Define the read callback function
lv_indev_drv_register( &indev_drv );//Registering Input Device Drivers
//Backlight settings
#ifdef TFT_BL
#endif
#ifdef TFT_BL
delay(500);
#endif
// UI initialization ui_init(); lv_timer_handler(); } ```
Main Program Part
void loop() { /*① obtain temperature and humidity data and store it in a char array. First, use two integer variables a and b to store the obtained temperature and humidity separately*/ char DHT_buffer[6]; int a = (int)dht20.getTemperature(); int b = (int)dht20.getHumidity(); /*Then store the values in the array and display them on the label label through conversion*/ snprintf(DHT_buffer, sizeof(DHT_buffer), "%d", a); lv_label_set_text(ui_Label1, DHT_buffer); snprintf(DHT_buffer, sizeof(DHT_buffer), "%d", b); lv_label_set_text(ui_Label2, DHT_buffer); /*To determine the value of the LED, in the ui. c program, press the "ON" button to set the LED to 1, and control the LED light to turn on.*/ if(led == 1) digitalWrite(38, HIGH); /*In the ui. c program, press the "OFF" button to set the LED to 0, and at this time, control the LED to turn off.*/ if(led == 0) digitalWrite(38, LOW); lv_timer_handler(); /* let the GUI do its work, only by executing this function can the entire animation run. */ delay( 10 ); }
