Hamza Deniz Yılmaz
  • 1 Projects
  • 3 Followers
  • Apr 06,2025
RGB Control System With ESP32-C6
RGB LED Strip Control System – Special Project Guide
🌟 PROJECT OVERVIEW
This document outlines an ESP32-based RGB LED control system with the following features:
  • 2-channel PWM control (for red and green LED strips)
  • Automatic relay control after 7:00 PM (based on Turkey/Istanbul time)
  • Web interface and physical button control
  • HC-SR04-based presence detection for energy saving
  • LED dance mode based on Ankara weather data
🛠️ HARDWARE DETAILS
🔧 Required Components:
  • ESP32 DevKit v1 (1 unit)
  • IRFZ44N MOSFET (2 units - for red and green LED strips)
  • 5V Relay Module (1 unit - room light control)
  • HC-SR04 (1 unit - distance measurement)
  • 128x64 OLED (I2C) (GPIO6 SDA, GPIO7 SCL)
  • 10K Potentiometer (2 units - GPIO4 and GPIO5)
  • Push Button (3 units - GPIO8, GPIO9, GPIO10)
  • 10K Resistor (5 units - for pull-up)
  • Breadboard (1 unit)
  • Jumper Wires (20+ units)
🎛️ Pin Mapping:
ESP32 --> GPIO4 --> POT1 (Red LED control) ESP32 --> GPIO5 --> POT2 (Green LED control) ESP32 --> GPIO8 --> BTN1 ESP32 --> GPIO9 --> BTN2 ESP32 --> GPIO10 --> BTN3 ESP32 --> GPIO12 --> MOSFET1 (Red LED) ESP32 --> GPIO13 --> MOSFET2 (Green LED) ESP32 --> GPIO21 --> RELAY1 (Room Light) ESP32 --> GPIO7 --> OLED_SCL ESP32 --> GPIO6 --> OLED_SDA ESP32 --> GPIO14 --> TRIG (HC-SR04 Trigger) ESP32 --> GPIO15 --> ECHO (HC-SR04 Echo) MOSFET1 --> LED1 (Red LED Strip) MOSFET2 --> LED2 (Green LED Strip) RELAY1 --> LIGHT (Room Light)
⚡ Power Management:
  • ESP32: 120mA
  • LED Strip (12V): 2000mA
  • Relay Module: 80mA
  • HC-SR04: 15mA
  • OLED Display: 25mA
💾 SOFTWARE SETUP
📥 Required Libraries:
Core Libraries:
  • Adafruit_GFX (v1.10.12)
  • Adafruit_SSD1306 (v2.5.7)
  • WiFi (v2.0.0)
  • ESPAsyncWebServer (v3.1.0)
Time and Weather:
  • NTPClient (v3.2.1)
  • ArduinoJson (v6.19.4)
  • HTTPClient (v1.2)
⚙️ Code Structure:
/RGB-Control-System-with-ESP32-C6 ├── /web-server │ ├── config.php │ ├── connect.php │ ├── color.php │ └── relay.php ├── /includes │ └── functions.php └── index.php └── /src ├── main.ino └── settings.h
🔄 Flashing Process (Arduino IDE):
  • Tools > Board > ESP32 Dev Module
  • Flash Mode: "QIO"
  • Flash Size: "4MB (32Mb)"
  • Partition Scheme: "Default 4MB"
Custom Settings:
#define WIFI_SSID "YourSSID" #define WIFI_PASS "YourPassword" #define OWM_API_KEY "YourAPIKey"
🎛️ SYSTEM FEATURES
💡 LED Control System:
PWM Features:
  • 8-bit resolution (0–255)
  • 5kHz PWM frequency
Control:
  • POT1: Red LED intensity
  • POT2: Green LED intensity
⏱️ Time-Based System:
  • Timezone: Turkey/Istanbul (GMT+3)
  • Relay activation based on HC-SR04 after 7:00 PM:
    • Person detected: ON
    • No presence: OFF
🌤️ Weather Integration:
  • Ankara weather (OpenWeatherMap API):
    GET https://api.openweathermap.org/data/2.5/weather?q=Ankara,TR&appid=YOUR_API_KEY&units=metric&lang=en
  • BTN3 (double click): Activates dance mode — LEDs synchronize based on weather
🖥️ USER INTERFACE
📺 OLED Menu Structure:
  • Main Menu
    • LED Values → Red: 0–255 / Green: 0–255
    • Relay Status → ON/OFF
    • MOSFET Status → PWM Setting / ON/OFF
🕹️ Button Controls:
BTN1:
  • Single Click: Menu Down
  • Double Click: Relay Status
  • Usage: POT1 Value Adjustment
BTN2:
  • Single Click: Menu Up
  • Double Click: MOSFET Status
BTN3:
  • Single Click: Confirm Selection
  • Double Click: Dance Mode
  • Usage: Toggle Options
🌐 Web Interface:
Endpoints:
  • / → Homepage
  • /relay/on → Turn Relay ON
  • /relay/off → Turn Relay OFF
🔧 TROUBLESHOOTING GUIDE
🚨 Common Issues:
LEDs Not Working:
  • Check MOSFET gate resistor (10K–100Ω)
  • Verify 12V power supply
  • Lower PWM frequency (try 500Hz)
HC-SR04 Inaccurate Readings:
#define TRIG_PULSE 10 // 10μs trigger pulse #define MAX_DISTANCE 400 // Max 4 meters
WiFi Connection Problems:
WiFi.mode(WIFI_STA); WiFi.begin(ssid, password, 6); // Use channel 6
📊 Serial Monitor Test Commands:
  • SYSTEM INFO → System Information
  • LED TEST RED 255 → LED Test
  • RELAY TOGGLE → Relay Test
  • SENSOR READ → Sensor Test
📈 ADVANCED SETTINGS
⚙️ EEPROM Configuration:
  • 0x00: WiFi SSID (32 bytes)
  • 0x20: WiFi Password (64 bytes)
  • 0x60: LED Settings (16 bytes)
  • 0x70: Timing (32 bytes)
📜 LICENSE:
  • CERN-OHL-S-2.0
🤝 SPONSORS
📞 CONTACT & SUPPORT
This document covers all project details. For updates, follow the GitHub project page:
🔗 https://github.com/hamzadenizyilmaz/RGB-Control-System-with-ESP32-C6
  • ESP32 Code
    https://github.com/hamzadenizyilmaz/RGB-Control-System-with-ESP32-C6/tree/main/src
  • ESP32 Web Server
    https://github.com/hamzadenizyilmaz/RGB-Control-System-with-ESP32-C6/tree/main/web-server
23.8k
19
  • Like( 19 )
