Lesson3 Use SquareLine Studio and LVGL libraries to create a UI interface to light the lights¶
Welcome to the third lesson of learning. I believe that after completing the last two lessons, everyone has gained a deeper understanding of our product. Next, I will lead you to the second application case of the Advance series products - Display the interface by calling LVGL technology and control the on - off state of the small light bulb.
1. Product Interface Introduction¶
Connect the development board to the computer with a Type-C cable.
Note: For the development boards with sizes of 2.4 inches, 2.8 inches, and 3.5 inches, the default interface for flashing is USB0. For the development boards with sizes of 4.3 inches, 5.0 inches, and 7.0 inches, insert the small light bulb into the UART1-OUT port, and for development boards of other sizes, insert it into the UART-OUT port.
For the development versions with screen sizes of 4.3 inches, 5.0 inches, and 7.0 inches, the function select keys should be set to 01.
2. Introduce LVGL¶
3. Install SquareLine Studio¶
3.1 Installation Guide¶
Download the version 1.4.0
Click install.
Wait for installation.
Installation finish.
3.2 Software Function Introduction¶
Open the software
Note:Please select the corresponding resolution and color depth according to the screen specifications.
①Toolbar, including File, Export, and Help. Basic file operation bar, create or open files, export UI files and other operations. Click help and there are related introductory documents.
②Screen bar, the project screen will be listed here.
③Widget area, all widgets are here and can be selected and used according to project needs.
④Hierarchy area, it will show every widget used in each screen.
⑤This area shows the actual display effect, you can adjust the widgets or screen here.
⑥Material column, the added materials are displayed here.
⑦Setting bar, where you can make basic settings for each part, including the basic attributes and trigger operations of the part.
⑧Theme bar, different themes can be set.
4. Use SquareLine Studio to create UI control interfaces¶
4.1 Create a new SquareLine Studio project.¶
Here, I take a 2.8-inch screen as an example. After determining the resolution, I fill it in
The images can be found at the following location:
 https://github.com/Elecrow-RD/CrowPanel-Advance-4.3-HMI-ESP32-S3-AI-Powered-IPS-Touch-Screen-800x480/tree/master/Squareline_studio%20Instructions%20for%20use/code
Table_1amp image sizes are available for 3.5-inch, 4.3-inch, 5.0-inch, and 7-inch screens.
4.2 Add functions to the buttons to enable them to turn on and off lights¶
Select 'event' to add in the right sidebar.
After selecting, click ADD.
After adding, run
4.3 UI interface design completed, exporting UI files for easy use in subsequent code¶
Click on Project Setting
Set export path.
Complete the setup and export file.
Then use VSCode to open the IDF project folder. Copy the generated .h and .c files into the corresponding folders of the project. (Here, I will use the code for the 3.5-inch version as an example, the download link is provided in Part 5.)
5. Compile and flash the code¶
Note: This lesson takes the code of the 2.8-inch display screen as an example. The version of IDF used is 5.1.6. For the LVGL display and touch functions, call the pre-integrated function libraries in the display screen code corresponding to the relevant size, and there is no need to download and install them by yourself.
Step1:Download the files for lesson 3 from https://drive.google.com/drive/folders/1hEXyH14QeDgVdENxUfiYBQVCTbMbI6v9 and extract them, as shown below:
Click the link to access the lesson 3 folders in both big and small sizes, and select the code that matches your desired size.
Select the code folder for this lesson, right-click on it, and then choose to open it with VS Code.
Step3: Select a serial port to connect to the development board.
Step4: Select the chip model "esp32s3".
Note: Since there is an sdkconfig.defaults file in the project, IDF can automatically recognize the development board configuration from this file, eliminating the need for manual configuration of the development board.
Step6:Click”build”.
Wait for the compilation to be completed.
Step7: Click”Upload”.
Wait for the flashing to be completed.
After flashing the program, tapping "ON" on the screen will turn the LED on, and tapping "OFF" will turn the LED off.
