CrowPanel ESP32 Terminal SPI with MicroPython¶
Overview¶
The example tutorial is an environmental monitoring project, demonstrate how to create a UI and use a Humidity&Temperature sensor to obtain the environment temperature and humidity and display it on the screen; and how to control the LED on and off by the buttons on the screen.
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to upload the code with Thonny IDE.
Hardware Preparation¶
| ESP32 Terminal | Crowtail-AM2302 | Crowtail-LED |
Open the SquareLine Studio and create a project. Select "Desktop"->"Micropython for Unix and other platform".
Set the name of the project, set the screen resolution to 480*320, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
Please click
Add background.
Add events to buttons.
Export UI files.
Then click "APPLY CHANGES".
Build the Project with Thonny IDE¶
Download Thonny IDE¶
Go to the website https://thonny.org/ and download the corresponding software version (here we take the Windows version as an example)
Double-click the downloaded exe file to install the software.
Upload firmware¶
Connect the CrowPanel ESP32 HMI with your computer.
Open Thonny IDE and click "Tools"->"Options"->"Interpreter".
Select "MicroPython(ESP32)" for interpreter.
Select the corresponding serial port(or Try to detect port automatically).
Click "Install or update MicroPython (esptool)"
Click the icon with 3 lines, and click "select local MicroPython image...".Select the "lv_micropython.v1.19.1-ili9341-xpt2046.bin" and install.
Waiting for downloading...
Edit the code¶
Please click
to download the code file and libraries.
- The main code is "CrowPanel_ESP32_SPI_3.5.py"
- The "ui_image.py" is the libraries
- The ui.by is exported from Squaline Studio and needs to be copied into the main program
Code Explanation¶
Libraries imported in this example¶
import lvgl as lv
import time
from espidf import VSPI_HOST
from ili9XXX import ili9488
from ft6x36 import ft6x36
from machine import Pin, I2C
import time
import ui_images
import dht
import lvgl as lv: LVGL is an open source embedded system graphics library for creating graphical user interfaces.
import tft_config: Imports the TFT (Thin Film Transistor) configuration module. This library contains configuration information specific to TFT display devices.
import time: Used for time-related operations, such as delays.
import fs_driver: File system driver module, which may be used to access and manage storage devices.
import ft6x36: Driver library for the FT6X36 touch controller. The FT6X36 is a touch controller chip for touch screen devices.
from machine import Pin, I2C: Imports the Pin and I2C classes from the machine module. Pin is used to control hardware pins, and I2C is used for I2C communication.
import machine: The machine module usually contains control over hardware, such as GPIO (General Purpose Input Output) operations.
import ui_images: Imports the user interface image module, which may contain image resources for display.
import dht: Imports the DHT (Digital Humidity and Temperature) module, which is used to read humidity and temperature data from the DHT series sensors.
Basic Definition¶
Set up the hardware interface and initialize the sensor so that the subsequent program can read the temperature and humidity data and control the LCD display.
sensor = dht.DHT22(Pin(40))
#pin = 40
p11 = Pin(11, Pin.OUT)
p11.value(1) #Set the level of GPIO pin 11 to high
Initialize and configure the TFT display and touch screen, then start the LVGL event loop to start processing user interface interaction events.
disp = ili9488(miso=14, mosi=13, clk=12, cs=3, dc=42, rst=18,backlight=46, backlight_on=1, power_on=1,rot=0xa0|0x40,
spihost=VSPI_HOST, mhz=20,power=-1,
factor=16, hybrid=True, width=480, height=320,
invert=False, double_buffer=True, half_duplex=False)
touch = ft6x36(sda=2, scl=1)
UI display code¶
This part copies the code of ui.py generated by Squareline Studio. We need to modify the part that control the button.
From
to
Temperature and humidity display¶
Define a class named TEM_HUM to display temperature and humidity information in the LVGL GUI.
class TEM_HUM():
def __init__(self, ui_Screen1):
# Read the temperature and humidity values of the sensor
global Tem, Hum
Tem = sensor.dht20_temperature()
Hum = sensor.dht20_humidity()
# Update the temperature and humidity display on the UI interface
ui_Label4.set_text(f"{round(Tem)} °C") # Update temperature
ui_Label5.set_text(f"{round(Hum)} %") # Update humidity
Upload the code¶
Upload the libraries¶
ui_image
In the upper left corner of the thonny, enter the path where DHT20.py is located, right-click DHR20.py, and click Upload to/
Waiting for uploading
The ui_image.py will be added to the MicroPython device column.
Upload the code¶
Click the "run" icon to run the main code.
Successfully uploaded.
GPIO Examples¶
Please click
to download the example code files.
Example 1 LED Blinking¶
Plug the LED module to GPIO-D Port
Upload the led.py to board
The LED will blink
Example 2 Show the button on the screen¶
- Upload the button-3.5.py to the board
Example 3 Connect WiFi¶
Open the wifi.py
Modify the code to connect your WiFi
ssid = 'yanfa_software' # change to your network name
password = 'yanfa-123456' # change to your network password
- Upload the code
Example 4 Initialize SD card¶
Insert the SD card to the card slot
Upload the sd.py
Example 5 Make sounds¶
- Upload the buzzer.py
- The on-board buzzer will make some sounds
Example6 Serial port initialization¶
- Upload uart.py
