CrowPanel ESP32 Terminal SPI with ESP-IDF
Overview
The example tutorial is an environmental monitoring project, demonstrate how to create a UI and use a Humidity&Temperature sensor to obtain the environment temperature and humidity and display it on the screen; and how to control the LED on and off by the buttons on the screen.
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to build a project on ESP-IDF.
spi-demo
Hardware Preparation
ESP32 Terminal Crowtail-AM2302 Crowtail-LED
CrowPanel-ESP32-Content-T-SPI AM2302 CROWTAIL-LED
BUYNOW BUYNOW BUYNOW
GetStartedWithSquareLine
  1. Open the SquareLine Studio and create a project. Select "Arduino"->"Arduino with TFT_eSPI".
    SLS-UI-1
    Note:
    When select the Arduino framwork, there's only one option "Arduino with TFT_eSPI". By choosing this, the squareline studio will generate a template code suitable for the TFT_eSPI library. However, squareline studio not only supports the TFT_eSPI library, it supports a variety of libraries to suit different hardware and application needs. For example, Adafruit_GFX library, LovyanGFX etc.
  2. Set the name of the project, set the screen resolution to 480*320, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
    SLS-UI-2
  3. After creation, enter the following interface with a blank background.
    SLS-UI-3
  4. In the "Assets" area, click "ADD FILE TO ASSETS" to add custom images or icons.
    SLS-UI-4
    Note:
  5. Add background.
    SLS-UI-5
    SLS-UI-6
  6. Add Label widget to display temperature and humidity.
    SLS-UI-7
    SLS-UI-8
    SLS-UI-9
    SLS-UI-10
    SLS-UI-11
    SLS-UI-18
  7. Add Button widget to control the LED.
    SLS-UI-12
    SLS-UI-13
    SLS-UI-14
    SLS-UI-15
    SLS-UI-16
    SLS-UI-17
    SLS-UI-19
    SLS-UI-20
  8. Add events to buttons.
    SLS-UI-21
    SLS-UI-22
    SLS-UI-23
    SLS-UI-24
  9. Export UI files.
    SLS-UI-25
    SLS-UI-26
    Then click "APPLY CHANGES".
    SLS-UI-27
    SLS-UI-28
    SLS-UI-29
    You can click download to download the export UI files we provided.
    The UI file export is completed, and the button event function is also modified. Next we're going to learn about how to create a ESP-IDF project.
Create ESP-IDF Project
Get Started with ESP-IDF
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
GetStartedWithESPIDF
You can click download to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Create New Project
Create a new project according to the "Get Started with ESP-IDF". Choose "ESP320S3 chip(via ESP-PROG)" as ESP-IDF Target.
IDF-1
IDF-2
IDF-3
Add Libraries
Create a new folder and name the folder 'components'. Add the libraries we provided to this folder.
Please click download to download the libraries we provided.
IDF-4
IDF-5
Configuring the UI File
Modify CMakeLists.txt
Change from:
IDF-6
to:
idf_component_register(SRCS "ui.c"
            "ui_comp.c"
            "ui_Screen1.c"
            "ui_comp_button2.c"
            "ui_comp_hook.c"
            "ui_helpers.c"
            "ui_img_background_png.c"
            "ui_img_on_png.c"
            "ui_img_off_png.c"
    INCLUDE_DIRS "."
    PRIV_REQUIRES lvgl-3)
IDF-7
Modify the button event code.
First, define a extern int led; in the ui.h file to store the status of the LED. The value of this variable is judged to control the on and off of the LED.
SLS-UI-30
SLS-UI-31
  • When button 1 (ON button) is pressed, set the LED value to 1.
SLS-UI-32
  • When button 2 (OFF button) is pressed, set the LED value to 0.
SLS-UI-33
Setup main file
The CMakeList.txt file contains the Settings for the library. All required libraries should be included by directory address.
IDF-8
The main program is written in the .cpp file
IDF-9
#include "Arduino.h"
#define LGFX_USE_V1
#include <lvgl.h>
#include <LovyanGFX.hpp>
#include <Wire.h>
#include "FT6236.h"
#include "ui.h"
#include <stdio.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/gpio.h"
#include "rom/ets_sys.h"
#include "esp_rom_gpio.h"
#define DHT_22  GPIO_NUM_40
#define uchar unsigned char
#define uint8 unsigned char
#define uint16 unsigned short
//Definition of temperature and humidity
uchar uchartemp;//COM function call, data transfer
float Humi,Temp;
//uchar ucharT_data_H,ucharT_data_L,ucharRH_data_H,ucharRH_data_L,ucharcheckdata;//验证过后传递数据
uchar ucharT_data_H_temp,ucharT_data_L_temp,ucharRH_data_H_temp,ucharRH_data_L_temp,ucharcheckdata_temp;
uchar ucharcomdata;//Stores data obtained by com
int led;
const int i2c_touch_addr = TOUCH_I2C_ADD;
#define get_pos ft6236_pos
#define LCD_MOSI 13
#define LCD_MISO 14 // 12
#define LCD_SCK 12
#define LCD_CS 3
#define LCD_RST -1 // 26
#define LCD_DC 42  // 33
#define LCD_BL 46
#define I2C_SDA 2
#define I2C_SCL 1
#define SD_MOSI 13
#define SD_MISO 14
#define SD_SCK 12
#define SD_CS 10
#define LED 11
static void InputInitial()
    esp_rom_gpio_pad_select_gpio(DHT_22);
    gpio_set_direction(DHT_22, GPIO_MODE_INPUT);
static void OutputHigh(void)//output 1
    gpio_set_direction(DHT_22, GPIO_MODE_OUTPUT);
    gpio_set_level(DHT_22, 1);
static void OutputLow(void)//output 1
    gpio_set_level(DHT_22, 0);
static uint8 getData()//Read status
    return gpio_get_level(DHT_22);
//Read a byte of data
static void COM()
    uchar i;
    for (i=0;i<8;i++)
        while(!getData())
            uchartemp=0;
        ets_delay_us(35);//delay 35us
        if(getData()==1)
            uchartemp=1;
        ucharcomdata <<= 1;
        ucharcomdata |= uchartemp;
        while(getData());
void DHT22(void)   //Temperature and humidity sensor start
  OutputLow();
  ets_delay_us(1000);
  OutputHigh();
    ets_delay_us(40);
  InputInitial(); //input
  if(!getData())//Indicates that the sensor pulls the bus low
    //Waiting for the bus to be pulled high by the sensor
    while(!getData())
            ets_delay_us(10);
    //Waiting for the bus to be pulled low by the sensor
    while(getData())
          ets_delay_us(10);
    COM();//Read the first byte,
    ucharRH_data_H_temp=ucharcomdata;
    COM();//Read the second byte,
    ucharRH_data_L_temp=ucharcomdata;
    COM();//Read the 3rd byte,
    ucharT_data_H_temp=ucharcomdata;
    COM();//Read the 4th byte,
    ucharT_data_L_temp=ucharcomdata;
    COM();//Read the 5th byte,
    ucharcheckdata_temp=ucharcomdata;
    OutputHigh();
    //Determine whether the checksum is consistent
    uchartemp=(ucharT_data_H_temp+ucharT_data_L_temp+ucharRH_data_H_temp+ucharRH_data_L_temp);
    if(uchartemp==ucharcheckdata_temp)
        //Checksums are consistent,
        /*ucharRH_data_H=ucharRH_data_H_temp;
        ucharRH_data_L=ucharRH_data_L_temp;
        ucharT_data_H=ucharT_data_H_temp;
        ucharT_data_L=ucharT_data_L_temp;
        ucharcheckdata=ucharcheckdata_temp;*/
        //Storage temperature and humidity
        Humi=ucharRH_data_H_temp;
        Humi=((uint16)Humi<<8|ucharRH_data_L_temp)/10;
        Temp=ucharT_data_H_temp;
        Temp=((uint16)Temp<<8|ucharT_data_L_temp)/10;
    else
      Humi=100;
      Temp=100;
  else //If the read is unsuccessful, return 0
    Humi=0,
    Temp=0;
    Serial.println(123);
  OutputHigh(); //Output
    lgfx::Panel_ILI9488 _panel_instance;
    lgfx::Bus_SPI _bus_instance;
public:
    LGFX(void)
            cfg.spi_host = SPI3_HOST;
            cfg.spi_mode = 0;
            cfg.freq_write = 60000000;
            cfg.freq_read = 16000000;
            cfg.spi_3wire = true;
            cfg.use_lock = true;
            cfg.dma_channel = SPI_DMA_CH_AUTO;
            cfg.pin_sclk = LCD_SCK;
            cfg.pin_mosi = LCD_MOSI;
            cfg.pin_miso = LCD_MISO;
            cfg.pin_dc = LCD_DC;
            _bus_instance.config(cfg);
            cfg.pin_cs = LCD_CS;
            cfg.pin_rst = LCD_RST;
            cfg.pin_busy = -1;
            cfg.memory_width = 320;
            cfg.memory_height = 480;
            cfg.panel_width = 320;
            cfg.panel_height = 480;
            cfg.offset_x = 0;
            cfg.offset_y = 0;
            cfg.offset_rotation = 0;
            cfg.dummy_read_pixel = 8;
            cfg.dummy_read_bits = 1;
            cfg.readable = true;
            cfg.invert = false;
            cfg.rgb_order = false;
            cfg.dlen_16bit = false;
            cfg.bus_shared = true;
            _panel_instance.config(cfg);
        setPanel(&_panel_instance);
bool connected_state = false; //Create a device connection identifier
LGFX lcd;
/*Change to your screen resolution*/
static const uint16_t screenWidth = 480;
static const uint16_t screenHeight = 320;
static lv_color_t buf[screenWidth * screenHeight / 5];
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
    uint32_t w = (area->x2 - area->x1 + 1);
    uint32_t h = (area->y2 - area->y1 + 1);
    lcd.startWrite();
    lcd.setAddrWindow(area->x1, area->y1, w, h);
    lcd.writePixels((lgfx::rgb565_t *)&color_p->full, w * h);
    lcd.endWrite();
    lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
    int pos[2] = {0, 0};
    ft6236_pos(pos);
    if (pos[0] > 0 && pos[1] > 0)
        data->point.x = lcd.width() - pos[1];
        data->point.y = pos[0];
        Serial.printf("x:%d,y:%d\n", data->point.x, data->point.y);
    else
void touch_init()
    // I2C init
    Wire.begin(I2C_SDA, I2C_SCL);
    byte error, address;
    Wire.beginTransmission(i2c_touch_addr);
    error = Wire.endTransmission();
    if (error == 0)
        Serial.print("I2C device found at address 0x");
        Serial.print(i2c_touch_addr, HEX);
        Serial.println("  !");
    else if (error == 4)
        Serial.print("Unknown error at address 0x");
        Serial.println(i2c_touch_addr, HEX);
        lcd.setCursor(10, 40);
        lcd.println("Touch Failed");
extern "C" void app_main()
    Serial.begin(115200); /* prepare for possible serial debug */
    pinMode(11, OUTPUT);
    digitalWrite(11, LOW);
    lcd.begin();        /* TFT init */
    lcd.setRotation(3); /* Landscape orientation, flipped */
    lcd.fillScreen(TFT_BLACK);
    delay(500);
    pinMode(LCD_BL, OUTPUT);
    digitalWrite(LCD_BL, HIGH);
    touch_init();
    lv_init();
    lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * screenHeight / 5);
    /*Initialize the display*/
    lv_disp_drv_init(&disp_drv);
    /*Change the following line to your display resolution*/
    /*Initialize the (dummy) input device driver*/
    // uncomment one of these demos
    ui_init();
    Serial.println("Setup done");
    while (1)
        DHT22();
        Serial.println(Temp);
        Serial.println(Humi);
        printf("Temp=%.2f--Humi=%.2f%%RH \r\n", Temp,Humi);
        char DHT_buffer[6];
        int a = (int)Temp;
        int b = (int)Humi;
        if(a!=0 || b!=0){
        if(led == 1)
            digitalWrite(11, HIGH);
        if(led == 0)
        delay(5);
Upload the code
Board Setting
IDF-10
IDF-11
IDF-12
Confirm the path
IDF-13
SDK Configuration
IDF-14
  1. Serial flash config:
    IDF-15
  2. ESP32SE-Specific→Cache config:
    IDF-16
    IDF-17
  3. LVGL Configuration: Uncheck the "Uncheck this to use custom lv_conf.h"
    IDF-18
  4. Save the setting
    IDF-19
Compile and upload the code
Click Compile and the compilation is successful.
IDF-20
Click the download button to download the program (confirm the serial port and select UART mode to download)
IDF-21
spi-demo
Resources
