CrowPanel ESP32 7.0-inch with ESP-IDF
IDF Version V5.5.4 Ivgl: 8.3.11
Overview
In this tutorial, we will show you how to design the UI with SquareLine Studio, and show you how to upload the code with ESP-IDF.
Hardware Preparation
CrowPanel ESP32 7.0'' HMI Crowtail-DHT20 Crowtail-LED Dupont-wire
CrowPanel-ESP32-7-0inch CROWTAIL-DHT20 CROWTAIL-LED 4-PIN-FEMALE-WIRE
BUYNOW BUYNOW BUYNOW BUYNOW
GetStartedWithSquareLine
  1. Open the SquareLine Studio and create a project.
    Set the name of the project, set the screen resolution to 800*480, set the color depth to 16bit, and keep other default settings. After setting, click CREATE to create the project.
  2. After creation, enter the following interface with a blank background.
  3. In the "Assets" area, click "ADD FILE TO ASSETS" to add custom images or icons.
    Note:
    Images only support webp format. The pixels of the image need to be smaller than the pixel size of the screen used in your project. The size of each image should not exceed 100k, preferably within 30k, to provide a smooth display effect.
  4. Add background.
  5. Add Label widget to display temperature and humidity.
    You can set the font colour and other attributes in STYLE SETTING→STYLE(MAIN).
  6. Add Button widget to control the LED.
  7. Add events to buttons.
    Select "clicked" as the trigger condition, select a trigger event in "Action". It will be modified in the generated program to achieve the LED control function.
  8. Export UI files.
    2
    3
    Then click "APPLY CHANGES".
    You can click download to download the export UI files we provided.
Build the Project with ESP-IDF
Get Started with ESP-IDF
Please click the card below to learn how to install ESP-IDF. Create a blank project according to the "Get Started with ESP-IDF".
You can click download to download the complete project we provided. This project can be used directly. You can also create the project by following the tutorial.
Library introduction
#include <lvgl.h>
#include <DHT20.h>
#include <SPI.h>
#include <Arduino_GFX_Library.h>
#include <Arduino.h>
#include "ui.h"
  • #include <lvgl.h>: Library for UI interaction
  • #include <DHT20.h>: The library of temperature and humidity sensors
  • #include <SPI.h>: Screen driven library.
  • #include <Arduino.h>: This is the core Arduino header file. It must be included when using the Arduino framework.
  • #include <Arduino_GFX_Library.h>: This library handles the initialization and configuration of the display, including resolution, driver settings, and interface pins.
  • #include "ui.h": is a custom header file that contain UI-related functions or definitions.
Code Explanation
Basic Definition
  • Set the screen cache
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
    41 /* DE */, 40 /* VSYNC */, 39 /* HSYNC */, 0 /* PCLK */,
    // R0~R4
    14 /* R0 */, 21 /* R1 */, 47 /* R2 */, 48 /* R3 */, 45 /* R4 */,
    // G0~G5
    9 /* G0 */, 46 /* G1 */, 3 /* G2 */, 8 /* G3 */, 16 /* G4 */, 1 /* G5 */,
    // B0~B4
    15 /* B0 */, 7 /* B1 */, 6 /* B2 */, 5 /* B3 */, 4 /* B4 */,
    0 /* hsync_polarity */, 40 /* hsync_front_porch */, 48 /* hsync_pulse_width */, 40 /* hsync_back_porch */,
    0 /* vsync_polarity */, 1 /* vsync_front_porch */, 31 /* vsync_pulse_width */, 13 /* vsync_back_porch */,
    1 /* pclk_active_neg */, 9000000 /* prefer_speed */, false /* useBigEndian */,
    0 /* de_idle_high */, 0 /* pclk_idle_high */, 480 /* bounce_buffer_size_px */
Arduino_RGB_Display *lcd = new Arduino_RGB_Display(
    800 /* width */, 480 /* height */, bus, 0 /* rotation */, false /* auto_flush */);
  • Automatically refresh temperature and humidity data in real time.
void update_sensor_values() {
  int temperature = dht20.getTemperature();
  int humidity = dht20.getHumidity();
  if (ui_Label1) lv_label_set_text_fmt(ui_Label1, "%d", temperature);
  if (ui_Label2) lv_label_set_text_fmt(ui_Label2, "%d", humidity);
  Serial.print("Temp: ");
  Serial.print(temperature);
  Serial.println(" °C");
  Serial.print("Humi: ");
  Serial.print(humidity);
  Serial.println(" %");
  • Touch reading function
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
    if (touch_has_signal())
        if (touch_touched())
            data->point.x = touch_last_x;
            data->point.y = touch_last_y;
            Serial.printf("[LVGL] x=%d y=%d\n", touch_last_x, touch_last_y);
        else if (touch_released())
    else
    delay(15);
  • Refresh function
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
    uint32_t w = (area->x2 - area->x1 + 1);
    uint32_t h = (area->y2 - area->y1 + 1);
#if (LV_COLOR_16_SWAP != 0)
    lcd->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
    lcd->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#endif
    lv_disp_flush_ready(disp);
Setup Part
    Serial.begin(115200);
    delay(100);
    Serial.println("setup() start");
    dht20.begin();
    Wire.begin(19, 20); // still needed for DHT20
    // Control pin 38 (matching Arduino version)
    pinMode(38, OUTPUT);
    digitalWrite(38, LOW);
    lv_init();
    Serial.println("Calling lcd->begin()...");
    bool ok = lcd->begin();
    Serial.printf("lcd->begin() returned: %d\r\n", ok);
    if (!ok) {
        Serial.println("lcd->begin() failed, halt");
        while (1) {
            delay(1000);
    // Test: fill screen with black (matching Arduino version)
    lcd->fillScreen(0x0000);
    delay(100);
    touch_init();
    delay(50);
    //pinMode(38, OUTPUT);
    //digitalWrite(38, LOW);
    screenWidth = lcd->width();
    screenHeight = lcd->height();
    // Use 1/10 of screen as draw buffer (recommended for LVGL 8.x)
    const size_t draw_buf_pixels = screenWidth * screenHeight / 10;
    lvgl_draw_buf = (lv_color_t *)heap_caps_malloc(draw_buf_pixels * sizeof(lv_color_t),
                                                   MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT);
    if (!lvgl_draw_buf) {
        Serial.println("draw buffer alloc failed");
        while (1) {
            delay(1000);
    lv_disp_draw_buf_init(&draw_buf, lvgl_draw_buf, NULL, draw_buf_pixels);
    lv_disp_drv_init(&disp_drv);
    ui_init();
    // Backlight control (matching new board Arduino version)
#ifdef TFT_BL
    ledcAttach(TFT_BL, 300, 8);
    ledcWrite(TFT_BL, 255);
#endif
    pinMode(TFT_BL, OUTPUT);
    digitalWrite(TFT_BL, LOW);
    delay(500);
    digitalWrite(TFT_BL, HIGH);
    Serial.println("Setup done");
Main Program Part
    static uint32_t last_tick_ms = millis();
    uint32_t now = millis();
    lv_tick_inc(now - last_tick_ms);
    last_tick_ms = now;
    lv_timer_handler();
    delay(5);
    // Handle LED state changes from UI button events
    if (led != last_led_state) {
        last_led_state = led;
        // TODO: Change LED_PIN to match your actual LED connection
        const int LED_PIN = 38;
        pinMode(LED_PIN, OUTPUT);
        digitalWrite(LED_PIN, led ? HIGH : LOW);
        Serial.printf("LED state changed: %d\n", led);
    static unsigned long last_update = 0;
    if (millis() - last_update > 2000) {
        update_sensor_values();
        last_update = millis();
Setup board
5
6
Download the program
Connect the ESP32 Display to the PC and compile the program.
7
After confirming the serial port, select the UART mode.
8
After the program is successfully downloaded, connect the DHT20 sensor to the IIC port and the LED to GPIO_D (IO25), the temperature and humidity values will be displayed on the screen. Click the ON button on the screen and the LED will turn on. Click the OFF button and the LED will turn off.
