5.Port Introduction
Welcome to Lesson 5 of the CrowPanel ESP32 Advance HMI Series Tutorial, Port Introduction.
This lesson will use the IIC interface and UART1-OUT interface of this series of products to collect data from temperature and humidity sensors. When the temperature exceeds the threshold, the light bulb will automatically light up.
In this lesson, we will use the knowledge of LVGL graphics library from Lesson 3 to create an interactive interface.
1 Introduce product ports
1_2
When using the UART1-OUT interface, please set the switch dial to 0 1 mode, as the wireless module and the UART1-OUT line are controlled together. (For 4.3 size, 5.0 size, 7.0 size)
1_2_1
2 Taking UART1-OUT interface and IIC-OUT as examples
Next, taking the external light bulb connected to the UART1-OUT interface and the temperature and humidity sensor connected to the IIC-OUT interface as an example. The temperature and humidity sensor needs to support IIC communication. The peripherals connected to the IIC interface are all like this.
In order to provide everyone with an intuitive observation, I will use LVGL to create an interactive interface.
1_4
Create Arduino project
1_5
1_3
1_6
1_7
1_7_1
1_12
1_8
1_9
1_11
1_13
1_16
1_14
1_15
1_18
1_20
1_17
1_19
1_22
Click on Project Setting
1_24
Set the file export path and customize the path
1_21
But here, you need to create an Output folder in the path above to receive the exported UI files.
1_23
Fill in lvgl. h and select Flat export.
1_26
Finally confirm the settings
1_28
1_25
Go to the Output folder you just set up and copy the UI files you generated.
1_27
Paste it into the code file you need to open (here I will introduce the 3.5-size code as an example).
1_29
Then use Arduino IDE to open the ino file in the folder
1_30
3 Code Explanation
Introduce several key points in the code
Initialize UART1-OUT pin, IIC pin, and temperature and humidity sensor
1_33
Turn on the screen backlight to enable the screen to display
1_31
Previously, pin 18 was set as the output mode, and the UART1-OUT interface was connected to the light bulb. By controlling pin 18, the light can be controlled.
The brightness and darkness of bubbles.
1_32
Because the temperature and humidity sensor is connected to the IIC interface, it is necessary to initialize pins 15 and 16 of the IIC and initialize the temperature and humidity sensor.
1_34
And define two variables to receive data collected by temperature and humidity sensors
1_36
And display the value on the label you previously designed
1_38
1_35
1_37
If the temperature value collected by your temperature and humidity sensor exceeds 30 ℃, the light bulb will automatically light up; If the temperature drops below 30 ℃, the light bulb will automatically turn off. (You can modify the temperature threshold yourself, this is only for the convenience of observing the results)
1_39
Special Reminder:(The following applies only to 2.8-inch and 2.4-inch products)
The IIC address of the 2.8 and 2.4 touch driver ICs is 0x38, and the IIC address of the DHT20 temperature and humidity sensor is also 0x38. When the DHT20 temperature and humidity sensor is connected to the IIC-OUT interface for use, the two addresses conflict, causing abnormal device usage. The DHT20 temperature and humidity sensor will no longer work, but will ensure the driving of the touch IC.
So in order to make the DHT20 temperature and humidity sensor work, we can connect the DHT20 temperature and humidity sensor to UART1-OUT.
Special note: The UART1-OUT interface allows the use of two or fewer IO interfaces, namely 17 and 18 pins, for your convenience. For example, when connecting a light bulb, 18 pins can be used to receive the initiated control signal. For example, doing digital input/output and analog input/output. There are also some infrared receivers, buzzers, and lights that can be connected. The premise is that you should not use more than 2 IO ports, such as SPI, which requires four IO ports to control and cannot be used.
2.4" 2.8"
1_40
1_41
And when initializing the temperature and humidity sensor, specify the IIC pin used for initializing the temperature and humidity sensor.
1_42
4 Hardware connection
UART1-OUT connection bulb
IIC-OUT connection to DHT20 temperature and humidity sensor
1_44
5 Configure the environment, upload code, and view phenomena
(Before uploading the code, please replace the relevant library files. Please refer to Lesson 2 for instructions on how to replace them.)
Configure the operating environment according to the guidance.
1_43
Upload code
1_46
Phenomenon display
1_48
1_45
1_47
new-1
new-2
new-3
new-4
new-5
new-6
